sedan a14net astra oil gear
A14net Astra sedan oil gear
Haloo friends
I want ask about gear oil change
Whan I need to replace ?
Tnx
My car drive 95000 km auto gear
The oil is meant to be lifetime so in theory doesn't need changing.
But I changed mine at 27000m
And you fill something after the replacement?
DEXRON 6 fluid, you gonna need some sort of diagnostic tool that can tell you the fluid temperature. Fluid needs to be at 85-95C when checking the level. Slight underfill doesn't hurt but slight overfill will make box shift like crap.
  Passenger Door won't open - Astra GTC everson38 6 7,212 17:th-Jun-2021, 13:05:42
  Astra J Total power loss Galway11 2 5,957 15:th-Dec-2020, 16:37:26
Last Post: Galway11
  Astra J Power Sounder dawks 4 8,296 20:th-Nov-2019, 18:27:56
  Astra J 1.7cdti - oilk catch can milika 0 5,365 2:nd-May-2019, 23:27:18
Last Post: milika
  Astra J 1.7CDTi - Boost sensor location for Chipbox jason.dexter 8 14,586 4:th-Feb-2019, 14:40:25
Last Post: rlievens
  Opel Astra J interior fan problem hejhopp123 3 10,275 21:st-Oct-2018, 21:35:28
  Astra J 1.7 CDTI Tech-Line rear light cluster issue AstraCDTI 1 8,716 29:th-Aug-2018, 07:27:16
  Re-map astra j 2.0 cdti ecoflex kyle-astra-j 8 11,889 4:th-Feb-2018, 22:55:44
Last Post: Iaintruten
  Astra J to an Astra K everson38 2 6,898 4:th-Jan-2018, 23:07:55
Last Post: everson38
  Astra GTC projector or reflector headlights? GreevaGTC 4 9,979 6:th-Oct-2017, 07:13:55
