Car won't start after installing led and door cards!!
Help Guys!!! My car now won't start after installing the LEDs and door card, when I turn the key the car just make some awful noises (like the battery has died or something) and then it won't start!! It also spat the disc out of the disc tray for some reason :-/
Anyone any idea why this has happened?! Kind of need my car for work so I'm buggered it I can't get it working!
Black filter/cap under coolant cap won't budge
When I unscrew the cap to the coolant tank there's a black cap or filter there that won't come out, coolant won't seep through it either so I can't put any in.
Astra won't start after some sensor cleaning?
Hey vxoc !
My car wont start anymore after i cleaned the EGR and suction control valve (scv) and the MAP sensor. the last thing that happened was whistle turbo sound from the engine and it went to ''reduced power mode'' when i sae that i parked the car it i dint turn on since.. but before all that i was haveing with power and stalling issues for the last month and after some internet research i begend to clean the sensors.
here are the error codes i got from opcom hopefully someone can he
Astra j bonnet won't open help
Help bonnet won't open . The leaver goes all the way with no resistance. Bonnet does not pop up .
Passenger Door won't open - Astra GTC
Hey Guys,
So recently noticed an issue. On my 62 plate 1.7 Astra GTC.
When I unlock the car and open and try to get into the passenger side door, the door won't open no matter how much I pull on it?
Any ideas
Thanks?
