to lowering a fit springs gtc how rear
How-to fit rear lowering springs to a GTC
This is a how-to for fitting rear springs to a GTC the 5dr will be similar
Tools required
Trolley Jack
Qty 2 Axle stands
Locking wheel nut key
19mm socket
21mm Socket
Breaker Bar
Ratchet
Torque Wrench
New lower shock bolt part no. 11610587
Start by loosening off the wheel nuts on both rear wheels using the 19mm socket and locking wheel nut key
Jack up the rear of the car from the centre of the rear axle
Then support each side with axle stands on the chassis rail and lower the trolley jack enough for the weight to be transferred to the axle stands
Remove both rear wheels
Loosen and remove both the lower shock bolts these are 21mm
Lower the trolley jack completely so that the rear axle is free to move
Remove both rear springs by pushing the lower seat fully down to allow the springs to be removed
Swap over both the rubber insulators
This is a comparison between the springs(the middle one was incorrectly sent) the lowering springs look longer as they have a helper spring to prevent them falling out when suspension is fully extended
Raise the rear axle enough to reinstall the lower shock bolts and torque them to 150 Nm(111 lbft) + 60°
Refit the wheels then jack up to enable the axle stands to be removed. Lower the vehicle and torque the wheel nuts to 140 Nm (100 lb ft).
This is how the rear looks after fitting
Nice how to, all I need now is a gtc vxr
well done
nice tut fella
Cheers guys fronts on the way
Brilliant threads, just read both, an springs have arrived, just need a hub puller then Im in business. This is why I love forums, the wealth of knowledge.
  Astra GTC Hi-Per Strut lowering springs fitting cornishtaz 9 17,035 9:th-Feb-2020, 14:23:36
Last Post: seosamh1968
  How to front and rear brake pads removal 5Door Rusty2009 39 40,049 12:th-Aug-2019, 10:55:52
