Eibach Lowering Springs
Picked up a set of pro springs quite a while back for a billy bargain from eBay.
Not got round to fitting them yet but wondered if anyone else had and what their opinion was. I find the J has quite a bit of body roll (maybe I should slow down!) so wondered what difference this would make.
Front springs
I've just bought some lowering springs. Just a question on how the shock absorber is bolted on at the top mount. I can only see one bolt? Was expecting more than one. Cheers
How-to fit rear lowering springs to a GTC
This is a how-to for fitting rear springs to a GTC the 5dr will be similar
Tools required
Trolley Jack
Qty 2 Axle stands
Locking wheel nut key
19mm socket
21mm Socket
Breaker Bar
Ratchet
Torque Wrench
New lower shock bolt part no. 11610587
Start by loosening off the wheel nuts on both rear wheels using the 19mm socket and locking wheel nut key
Jack up the rear of the car from the centre of the rear axl
Astra GTC Hi-Per Strut lowering springs fitting
A quick how-to for fitting lowering springs to a GTC/VXR. These cars are fitted with the same suspension set-up as the Insignia VXR known as the Hi-Per Strut
Tools required
Trolley jack
Axle stand
E20 socket
T30, T40, T50 torx
8mm, 18mm, 19mm, 21mm, 24mm, 32mm sockets, through socket is best for the strut upper mount fixing
18mm, 21mm spanner
Hub puller
Ratchet
Breaker bar
Soft fac
Lowering springs...
Does anybody live in an area with a lot of speed bumps and have lowered there car
if so how low have you gone and have you seen much difference?
Eibach Pro-Kit Sportline lowering springs
Brand new, bought by me but never fitted. Still has protective brown paper around springs.
For Astra J 5 door hatch 1.7cdti and 2.0cdti
£100 plus delivery (not sure on that yet but prob around £25) or collection from PO13 area.
[Image: http://i679.photobucket.com/albums/vv155...a84976.jpg]
[url=http://s679.photobucket.com/user/MattC3156/media/
SRI springs
Am I right in thinking that the SRI springs are 10mm shorter than the other models?
EIBACH LOWERING SPRINGS [SOLD]
30mm springs
I know the 40mm eibach springs are supposed to be the best but 40mm seems a bit much for me,
Anyone heard of these springs
http://www.gnjmotorsport.com/search-by-c...dti-10-09/
Springs help!
Hi all
Wondering if you can advise on springs. Been researching a lot the last week or so and still a little unsure, but getting there!
So I want to lower the car (2014 2litre CDTI 165bhp diesel).
Eibach pro kit seem to be the commonly used springs, hwoever, I've seen reference to the Eibach Sportlines and where the pro kit and the sportlines have been discussed, people are saying the sportlines are worth it as they're a lot lower and the drop with the pro kit isn't that noticable.
