tucpal - Replies:
lowering
i know loads of you on here have lowered you cars
and i swore blind i would not lower this car
but it is going to happen soon
i know the eibach springs are the best
but i really want to upgrade the front and rear dampers
at the same time say for the bilsten b6 or something like that
so has any one ungraded there dampers and if so what did you go for.
Eibach Lowering Springs
Picked up a set of pro springs quite a while back for a billy bargain from eBay.
Not got round to fitting them yet but wondered if anyone else had and what their opinion was. I find the J has quite a bit of body roll (maybe I should slow down!) so wondered what difference this would make.
How-to fit rear lowering springs to a GTC
[align=center][Image:
This is a how-to for fitting rear springs to a GTC the 5dr will be similar
Tools required
Trolley Jack
Qty 2 Axle stands
Locking wheel nut key
19mm socket
21mm Socket
Breaker Bar
Ratchet
Torque Wrench
New lower shock bolt part no. 11610587
Start by loosening off the wheel nuts on both rear wheels using the 19mm socket and locking wheel nut key
Jack up the rear of the car from the centre of the rear axl
Astra GTC Hi-Per Strut lowering springs fitting
A quick how-to for fitting lowering springs to a GTC/VXR. These cars are fitted with the same suspension set-up as the Insignia VXR known as the Hi-Per Strut
Tools required
Trolley jack
Axle stand
E20 socket
T30, T40, T50 torx
8mm, 18mm, 19mm, 21mm, 24mm, 32mm sockets, through socket is best for the strut upper mount fixing
18mm, 21mm spanner
Hub puller
Ratchet
Breaker bar
Soft fac
Lowering springs...
Does anybody live in an area with a lot of speed bumps and have lowered there car
if so how low have you gone and have you seen much difference?
Eibach Pro-Kit Sportline lowering springs
Brand new, bought by me but never fitted. Still has protective brown paper around springs.
For Astra J 5 door hatch 1.7cdti and 2.0cdti
£100 plus delivery (not sure on that yet but prob around £25) or collection from PO13 area.
[Image: http://i679.photobucket.com/albums/vv155...a84976.jpg ]
[url=http://s679.photobucket.com/user/MattC3156/media/
tucpal - Replies:
EIBACH LOWERING SPRINGS [SOLD]
Astra 13tdci lowering
Like to no best lowering springs for above Astra 13cdti Or if anyone as any for sale Thanks!!
Lowering Astra j
Wanting to know if any1 has lowered Astra j vxline 2.0 cdti on 19".
Vauxhall astra J 2.0 cdti ecoflex elite 165bhp lowering
Hi. Fitted a set of 19" on my car and wondered if any1 has any idea how much I can lower it by (mm) with having any problems with rubbing etc.
