pdc wiring diagram front
Front PDC wiring diagram
Hi. I need help. I want to retrofit front and rear PDC. I installed module, switch, rear wiring harness(bumper and loom to the module) and front bumper wiring. Now i need to make some custom loom, to connect front bumper harness to the car. I have connectors, i just need some wiring diagram, to know, where to connect wires. I know, that this loom connect under the battery to the other wirings, but anyone have some wiring diagram, to know where to connect which wire?
[attachment=1235]
[attachment=1236]
(8:th-Jan-2021, 20:03:55)milozic Wrote: Hi. I need help. I want to retrofit front and rear PDC. I installed module, switch, rear wiring harness(bumper and loom to the module) and front bumper wiring. Now i need to make some custom loom, to connect front bumper harness to the car. I have connectors, i just need some wiring diagram, to know, where to connect wires. I know, that this loom connect under the battery to the other wirings, but anyone have some wiring diagram, to know where to connect which wire?
Ignore the UDP sensors
[Image: Front%20and%20Side%20Object%20Sensors%20...UDP%29.png]
  Retrofit front parking sensors (GTC) pedroc1999 3 2,385 27:th-May-2023, 23:46:17
Last Post: M.Duman
  Lowering springs identify front rear martinpe68 1 1,721 12:th-Sep-2021, 15:22:37
  Front suspension knock????? Sri~mike 10 8,142 22:nd-Dec-2020, 10:21:36
Last Post: M222RJF
  VXR Front Bumper onto a 5dr Bear 2 3,381 3:rd-Oct-2020, 11:48:59
  2017 GTC Limited edition - Front wheel noise Nathan191210 4 2,663 12:th-Jul-2020, 07:37:10
  Gtc 2017 1.4t 120 front brake disc size Nathan191210 2 2,818 25:th-Apr-2020, 07:41:05
  Can You Add Front Fogs to an Astra J? SAMW98SO 2 3,747 10:th-Apr-2020, 13:29:58
Last Post: SAMW98SO
  No sound on indicators, seat belt warning and quiet front parking sensors mpotsb 4 7,437 22:nd-Feb-2020, 19:24:53
Last Post: mpotsb
  Astra j vxr front seat Custerz90 7 8,895 31:st-Oct-2019, 16:30:42
Last Post: marablind
  Front Brakes + Discs sizing everson38 3 3,073 12:th-Aug-2019, 10:53:27
Qaranc (21:st-Oct-2023, 10:35:51)
