quantity f40 gearbox 0l of 165 astra oil?? 2 2014 hp
2014 Astra 2.0L 165 HP F40 gearbox quantity of oil??
  • Hi all,
I have searched around on so many forums now and unable to find a definitive answer as I have heard rumours of vauxhall overfilling the F40 gearbox so I have heard it holds 2.4L, 2.6L, 1.9L, I dont have a clue how much is in thereor whether should be putting in less than what I get out because that what I have seen on a few forums. Would really appreciate some guidance on this!! All I do know is I will be using Redline 75W-85 GL04 oil for it... but how much of it??? ??
Thanks for the help!
Vauxhall normally have a drain and fill bung so you used to drain the oil put the bung back in and refill through the fill bung until it starts to dribble out. Don't know if that has changed though for F40 box
F40 drain from the bottom fill from the top.
I've not heard of anyone complaint about the F40 box being overfilled under filled. Yes plenty of complaints about the M32 being overfilled and under filled.
In terms of the way to go drain out into a measuring jug and refill with the same amount that has come out. You will not get all of it out so this would save you over filling it.
It's how mine was done not had any issues.
Ah just read this lol, did it about 3 or 4 days ago... got out 1.7L and filled up with 1.9L..
Reckon that'll be problematic? could always use a little hand pump to siphon 200ml out
Thanks for the advice
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 2,542 12:th-Sep-2021, 15:24:05
  2.0 CDTi Auto Gearbox Oil Change Dennis S 0 1,586 13:th-Aug-2021, 14:29:25
Last Post: Dennis S
  Vxr bumper on 5 door Astra j Sh4rk2007 10 8,079 6:th-Jun-2021, 18:25:04
Last Post: jeniferbitcoin71
  New Battery for Astra J 2013 reg 1.7 diesel Galway11 6 3,590 13:th-May-2021, 11:38:55
  Astra J 1.4T Exhaust help sammpennington 1 3,810 12:th-May-2021, 14:29:50
Last Post: azajus
  Astra j gtc modifications BillyBryan 2 1,901 9:th-May-2021, 17:15:36
Last Post: Spaghetti
  Gearbox whine m32 Nathan191210 1 1,558 22:nd-Feb-2021, 09:18:27
  Astra J Fault code reader suggestions Euroshopper 1 2,038 22:nd-Feb-2021, 08:50:12
  Astra j bonnet won't open help Paul in sheppy 2 2,164 17:th-Feb-2021, 13:13:46
Last Post: Paul in sheppy
  Astra J GTC PDC bracket milozic 5 2,506 2:nd-Feb-2021, 09:39:35
