j 7cdti chipbox boost astra sensor 1 location for
Astra J 1.7CDTi - Boost sensor location for Chipbox
Hi guys,,
Does anyone know the location for the boost sensor on the astra J 1.7cdti ?  I need to fit my racechip box but unable to find the sensor.
Any help would be very grateful.
Is it not bolted by the RAD?
(25:th-Jan-2019, 20:38:58)Rusty2009 Wrote: Is it not bolted by the RAD?
nope. Its not in the same place as the 2.0
Will check when I get home if I dont forget. If I do feel free to remind me
(29:th-Jan-2019, 16:38:04)rlievens Wrote: Will check when I get home if I dont forget. If I do feel free to remind me
Done
jason.dexter Wrote:
rlievens Wrote:Will check when I get home if I dont forget. If I do feel free to remind me
Done
I'll put it in my agenda, otherwise I'll forget again
Thank you
Here you go. Was hard to photograph in the dark.
So this is a picture of the right top side of the engine bay.
Below the position I'm pointing at is your plug. Unplug it, plug it in the racechip cable and plug the other racechip cable where you just removed the plug.
I can't photograph the exact spot it's below and behind there but you will find it.
Did you find it?
  Exhaust Gas Temperature Sensor P2084 bagnallman 4 8,250 2:nd-Sep-2021, 08:17:51
Last Post: geoffsnook
  Passenger Door won't open - Astra GTC everson38 6 2,466 17:th-Jun-2021, 13:05:42
ABS sensor/ fault codes wrobsongtc 8 6,603 26:th-Mar-2021, 13:49:53
  Astra J Total power loss Galway11 2 2,699 15:th-Dec-2020, 16:37:26
Last Post: Galway11
  Astra J Power Sounder dawks 4 4,893 20:th-Nov-2019, 18:27:56
  Astra J 1.7cdti - oilk catch can milika 0 2,959 2:nd-May-2019, 23:27:18
Last Post: milika
  Gtc 1.6 cdti 136 fuel rail sensor location? harrykelly9 3 4,820 11:th-Nov-2018, 08:55:56
  A14net Astra sedan oil gear Gili056 3 3,722 22:nd-Oct-2018, 06:09:34
Last Post: crisse_fin
  Opel Astra J interior fan problem hejhopp123 3 7,091 21:st-Oct-2018, 21:35:28
  Astra J 1.7 CDTI Tech-Line rear light cluster issue AstraCDTI 1 5,474 29:th-Aug-2018, 07:27:16
Dominattor (4:th-Sep-2023, 01:16:29)
