FM and/or DAB antenna location - stationwagon
Hello..
Is there anyone that have a stationwagon that can help me with some pictures of the antenna location of either the FM and/or the DAB antenna module? If you go to the boot and pop out the buttons for the auto rear seats (auto falldown buttons) and look up to the rear quarter windows and see if the module(s) is either on the left or right side.. This will be a big help to me..
How to install Sat Nav to a safe location
This little gadget seems too obvious for me to post it online and technically it isn't a 'how to' guide. However, I'm sure there are drivers on this forum who may just have overlooked this idea so I'm posting it in case it helps someone.
Instead of having your TomTom stuck on the windscreen in your face, there is a 'gooseneck' available, some made my TomTom themselves and others that are after market. Mine is an after market one and may do the job better because as far as I know it is slightl
Foot well lights (live location)
Hi peeps, has any of you's installed foot well lights from the courtesy light via the drivers side A post on a GTC?. If so can you tell me the easiest way to locate the grey coloured live going up to it.
Got me beat ?
Horn location
Does anyone know exactly where the horn is? I know somewhere in the engine bay but from a quick look i cant see it and i cant really be jumping in to get at it. Its just that the horn is shite! (2016 gtc)
Pedal box remote location
Where do you people have your remotes? Mine is currently under my steering wheel but i keep smacking my knee on it as i get out and it kills and i cant have it on the left as i will get pressure sores. Thank you in advance
A/C pressure sensor location
Can someone tell me how to access the a/c  pressure sensor on a 2013 GTC
Brian
Astra J 1.7CDTi - Boost sensor location for Chipbox
Hi guys,,
Does anyone know the location for the boost sensor on the astra J 1.7cdti ?  I need to fit my racechip box but unable to find the sensor.
Any help would be very grateful.
Air intake pipe location
Hi thanks for letting me join.I have a question regarding the whereabouts of the air box intake pipe,It would appear that the intake end of the pipe is in the front offside wheel arch,I can’t seem to find the opening,any ideas please? Thanks.[/b]
Paint code location
Hi, the 'vin plate' just says about tyre pressures and there's no other plates I can see with the paint code on as you get in other Vauxhalls - in the J is it located somewhere I've missed?
If not... Does anyone know what the colour and/or paint code is for my car please? Many thanks[attachment=1187]
Passenger accessory relay location
Pouring over the wiring diagrams for the problem I have, tracing the current path to the front accessory socket, it runs via F1 and F6 via the passenger accessory relay.   Haynes is a bit light on relay info TBH.
There is power at F1, although there is no current flow, as though the circuit is open, but shorted to earth via my tester its there.  Done same at F6, nothing.  To my mind this suggests the relay is poss duff, My Haynes says the relay is in the passenger fusebox but there's nowt but
