home module j key signal coming astra diagram
Astra J Coming Home Module / Key Signal Diagram
Hey there guys!
I wanted to retrofit a Coming Home Module for my Astra J (A16XER).
The aftermarket Module needs a „door open“ signal to trigger the relay inside of it. I looked up in Autodata and searched the Internet but I cant find any useful information unfortunately. All I know is, the Body Control Module (BCM) should process the Signals but there are many cables to measure them all for my needed voltage signal.
Does somebody know or has a Wiring diagram/Pin assingment picture or something like that?
In the best case it should have a (short pulse) 12v Signal and no Canbus Data signal.
Thank you guys in advance!
Best regards from Austria,
Eric
See the attached more to follow.
  K9 Body Control Module X1.pdf (Size: 35.21 KB / Downloads: 192)
  K9 Body Control Module X2.pdf (Size: 26.74 KB / Downloads: 113)
  K9 Body Control Module X3.pdf (Size: 26.95 KB / Downloads: 105)
  K9 Body Control Module X4.pdf (Size: 34.93 KB / Downloads: 93)
  K9 Body Control Module X5.pdf (Size: 32.35 KB / Downloads: 108)
Last 2.
  K9 Body Control Module X6.pdf (Size: 26.46 KB / Downloads: 95)
  K9 Body Control Module X7.pdf (Size: 26.37 KB / Downloads: 88)
Ahh Rusty you‘re the best I knew I can count on you!!
Hey there Rusty again, today I had a look at your pdf files and I thought it would be K6/Pin 21. But this Pin isnt even in the named plug. I measured the whole plug for the signal and came to a result it would be K6/Pin 4, I provisonally tried the module with Pin 4 and it worked I guess but after connecting and triying it out, the remote unlock/lock doesnt work anymore if the module is connected to this pin. Only after disconnecting the module the unlock/lock action worked again. It seems like, if you put any load (a relay) to the related pin, it doesnt work.
Maybe did I miss any pins relating my unlock signal? :(
Have you tried K6 pin1 or 2 Or K2 pin15
Tried them all too yesterday, unfortunately nothing usefull :/
Isn‘t behind the Speedometer dash, the key transmitter module itself?
Yes it is.
To activate coming home mode you need:
1 remove the ignition key
2 open door
3 blink high beam ,
i check on my astra and it work
(15:th-Jan-2019, 17:24:27)BOLT Wrote: To activate coming home mode you need:
2 open door
3 blink high beam ,
Could be wrong, but I think the OP wants something different to this.
Pretty sure what you're suggesting is standard fitment on most Vauxhalls now, so the OP would already be able to do this.
  TPMS on Astra J GTC milozic 0 1,763 14:th-May-2023, 18:58:09
Last Post: milozic
  insignia cluster into astra? Tylerrattv 48 34,054 30:th-Jul-2021, 18:27:37
Last Post: theendfear
  Rear camera fit on Opel astra sports tourer info ;) Alienbv 24 19,212 26:th-Dec-2019, 13:00:29
  dab and fm signal up and down tzr608 31 14,475 15:th-Oct-2019, 19:58:04
Last Post: MikeyP247
  astra k cluster on astra j Maniacu 2 6,482 6:th-Jun-2019, 14:37:10
Last Post: Maniacu
  Astra J Instrument Cluster 32pin wiring diagram Milo629 0 5,432 22:nd-Jan-2019, 14:55:13
Last Post: Milo629
  Options to replace Navi 400 in 62 plate Astra Atarius 7 6,555 12:th-Sep-2018, 07:04:30
  Navi 900 to I-link/MyLink 950 Wiring diagram Tylerrattv 7 7,015 8:th-Sep-2017, 15:50:06
4 User(s) read this thread:
EricMod (9:th-Jun-2023, 07:41:27), dawid926 (23:rd-May-2023, 14:43:11), greg848484 (11:th-Jun-2023, 16:16:13), ziTneY (16:th-Oct-2023, 21:09:29)
