Bumper lacquer coming off
This little fella will be coming to trax
Is anyone coming to Bournemouth for the air show
JohnL - Replies:
This coming weekend
What are every ones plans?
Mines starting early but not got anything really planned. Probably going to take it easy as I've got a stag do coming up soon.
Romania's are coming
Romania's are coming.
Did anyone watch this? I recorded it and caught up on them in one go.
But all the way through I thought this can't be right, to me they showed only 1 side of Romania.
DaPa - Replies:
Cooling Fan coming on for a few seconds
Recently on two occasions after I have driven the car for a while, stopped and then re start the cooling fan has come on for a few seconds.
Could this be related to the thermostat wiring harness issue they had?
It is a 1.6 Petrol Auto
dp
EricMod - Replies:
Astra J Coming Home Module / Key Signal Diagram
Hey there guys!
I wanted to retrofit a Coming Home Module for my Astra J (A16XER).
The aftermarket Module needs a „door open“ signal to trigger the relay inside of it. I looked up in Autodata and searched the Internet but I cant find any useful information unfortunately. All I know is, the Body Control Module (BCM) should process the Signals but there are many cables to measure them all for my needed voltage signal.
Does somebody know or has a Wiring diagram/Pin assingment picture or something
Coolant light coming on when coolant is full (new sensor and no leaks) baffling me!
Hi everyone,
So randomly a couple of weeks ago I got "coolant level low" light on. So I topped it up a little. It came on again so I added a little more to the point that it's on or over where it should be. The error keeps popping up but it will disappear after 10-20 seconds.
[color=#ffffff][size=small]I've checked and there are no leaks and the coolant isn't going down at all. I've replaced the coolant sen
