No radio signal on android headunit
I have just replaced my cd400 with an android head unit from iceboxauto. Everyhthing is working great but can't tune radio, just searches but does not find any stations.
The cd400 had no signal issues. Does the DAB/FM antenna work for normal FM?
dabs signal , android head unit
guys ive been studing forums everywhere to get some info on the signal problems whilst using the window mounted antenna that are to be used with the dabs usb modules for android head units.
i fitted this unit
https://www.aliexpress.com/item/HD-1024-...0.0.JesoCG
and had to get the dabs module to suit with antenna
http://www.ebay.co.uk/itm/Digital-DAB-Ra...enna-For-A
dab and fm signal up and down
Hi i have a gtc 2013 with fm and dab factory but the signal for fm and dab seems to be rubbish . signal is up and down all the time.....any idea's why????
Astra J Coming Home Module / Key Signal Diagram
Hey there guys!
I wanted to retrofit a Coming Home Module for my Astra J (A16XER).
The aftermarket Module needs a „door open“ signal to trigger the relay inside of it. I looked up in Autodata and searched the Internet but I cant find any useful information unfortunately. All I know is, the Body Control Module (BCM) should process the Signals but there are many cables to measure them all for my needed voltage signal.
Does somebody know or has a Wiring diagram/Pin assingment picture or something
