absorber shock flexride replacement
Flexride shock absorber replacement
So I have the car for almost a year now so I just went to the MOT here in Belgium and it passed with 1 remark: the right rear shock absorber is leaking.
Here's the picture:
Partnumbers on the sticker:
44 2400 005 332
GM 13 252 385
AAGF
So I have a few questions:
1. When should I replace this? As soon as possible or can I wait several months without a problem (it passed MOT). Should I replace both at the same time?
2. Is it possible to replace it yourself or do you need special equipment/lifting bridge? I found this manual (non-flexride) but it looks too easy
3. I found these 2 on ebay, one new and one used. But they are from a GTC and the partnumbers don't really match. Will it fit nevertheless? I see different partnumbers for LHD and RHD, lowered or standard chassis, wheel size... So i'm guessing not
Partnumbers website thingy I found (https://www.ilcats.ru/opel/?function=get...anguage=en)
Many thanks for your answers!
That would be a fail in the UK.
Replace them now with new and do both, relatively straight forward job if you have a decent jack.
I would replace in pairs always better.
They are quite easy 2 bolts jack and axle stands will help.
Just need to find the parts then. I can probably order them at the local Opel garage but I'm afraid prices will be through the roof.
davidoff Wrote:That would be a fail in the UK.
Well, they do test its function aswell, and that was still good. So it still performs and they then but a remark on the form saying I should check it out. Lucky for me they did anyway
  astra j shock on standard vs lowered sport chassis obsidian 1 3,272 19:th-Apr-2025, 19:19:09
  GTC Horn Replacement ed-b 1 3,385 12:th-Jul-2021, 08:53:37
  Battery replacement - AGM or regular everson38 1 3,814 22:nd-Jun-2021, 10:37:05
Last Post: MarkAP68
  Glow plug replacement - Things to consider everson38 13 14,336 20:th-Jun-2021, 17:44:37
Last Post: everson38
  Changing Rear Shock Absorbers. Astra-J Hatch. Replace or reuse bottom bolts? Big Dave2 5 12,882 22:nd-Jun-2020, 11:35:40
Replacement discs and pads Iamthestig 3 6,890 23:rd-May-2018, 18:31:42
  Break Replacement sheppy1 15 19,605 17:th-May-2015, 21:40:02
