converter excusiv insignia channel 2 2011 wires speaker
2011 Insignia Excusiv 2 channel converter speaker wires
hi guys. im very new to this.
ive installed my fli 12" sub (power cable, remote and ground) but im having some trouble with the 2 channel output conveter going into the head unit. any diagrams or advice would be an absolute lifesaver!!
thanks in advance,
Steve
@zzattack will be the best person here to help you he's done loads with amps etc on his Insignia.
Got any specs on the sub (type/model)? If it supports high-level inputs you can grab those in the b-pillar which would be the fastest route. You could also choose to install the high-to-low converter in there, as there's plenty of space.
For a sub you really don't need stereo channels but if you want both you could tap into the signals behind the headunit which is a bit more work but functionally equivalent.
  Insignia DVD800 retrofit Paul2012 4 6,815 18:th-Jan-2021, 18:33:02
Last Post: Paul2012
  Insignia Mk1 - Cd400 upgrade? Toboe 6 9,766 1:st-Oct-2020, 06:42:48
  Insignia tpms AlexFitton 6 9,108 27:th-Jun-2020, 08:53:38
Last Post: AlexFitton
  Single mass flywheel conversion for a 2010 2.0 CDTI Insignia i.rosca 4 18,144 7:th-Mar-2017, 16:19:12
Last Post: vocky
