sheppy1 - Replies:
Astra/Insignia VXR Pedals
Just came across these VXR pedals which fit the Astra J:
http://www.ebay.co.uk/itm/Vauxhall-Insig...6016.l4276
This price is around about the standard price for what these sell for second hand but I know there aren't always many on eBay and sometimes they do sell for a fair bit more. I've purchased from this person before and if you message him and ask him to lower the price a little bit he probably will do.
tucpal - Replies:
My Insignia Elite, 2.0 CDTI. tucpal.
[Image:
[align=center]...............................................MY NEW PROGRESS THREAD BEGINS................................................
...........................................MY NEW VAUXHALL INSIGNIA ELITE 2.0 160 ECOFLEX.....................................
I now have a 62 Plate my13 Insignia 2.0 160 Ecoflex Nav Elite.
with the works on it and only 26 on the clock
i wont be using any other fo
sheppy1 - Replies:
2016 Insignia
Just saw that there have been some "spy" shots of the new Insignia along with some mock ups based on those spy shots... So what do you all think?
[Image:
http://i.imgur.com/O0sGyet.jpg ]
tucpal - Replies:
Multimedia interface, reverse camera, navi 600, insignia, astra j.
raimon - Replies:
Insignia Vectra Medium car?
How come the insignia and vectra is class a medium size car on your site, what's funny is you class mokka as large car.
Cheers.
tucpal - Replies:
GM SHARK FIN astra j/gtc/insignia
D92 - Replies:
Insignia hubs on an astra
Not sure if its possible, but would the insignia's hub bearing + break disks fit on the astra's hub & driveshafts, and would I also need the caliper's of the insignia as well?
http://www.ebay.co.uk/itm/381178682477 does look like its the same 3 bolt fitment onto the hub.
I ask as alloys I am after are in 5x120, but with PCD adapters would stick too far out the arch.
tucpal - Replies:
Factory Reverse Camera, Astra j/GTC, insignia
[Image:
[align=center]NAVI 600, INSIGNIA / ASTRA GTC, FACTORY REVERSE REAR CAMERA, RETROFIT.
FOR THE INSIGNIA WITH NAVI 600 ONLY, from 2010 TO 2013.
FOR THE ASTRA GTC NAVI 600 ONLY, from 2012 TO 2014.
Today i have activated the rear factory reverse camera for the pre facelifted insignia pre 2013
i have activated the factory camera on the navi 600 unit that i have in my 2013 insignia
as you may or may not
Advice needed regarding HID upgrade for a 2010 Insignia
Hello everyone!
I am the owner of a 2010 Insignia that is factory equipped with a pair of halogen headlamps. I should also mention it has headlamp washers and manual leveling.
I use this car daily mostly to and from work. During autumn / winter I finish work after night fall and my daily commute includes a 30 km piece of road through an unlit field that has been known to have the occasional jaywalking rabbit or other, larger, 4 hoofed creature.
I recently drove a friend's car equipped
i.rosca - Replies:
Single mass flywheel conversion for a 2010 2.0 CDTI Insignia
Hey guys!
My A20DTH160HP 2010 Insignia seems to be suffering from a worn out or damaged flywheel. It started with a small rattling noise and now, over the winter, the sound is louder than the aircon maxed out, the car vibrates at idle, it jutters whenever I shift gears or when I release the clutch pedal pulling off from a stand still. Engine braking also starts to sound like engine breaking.
Everyone seems to suspect that the flywheel is either worn out or damaged (the dampening springs
