9:th-Oct-2017, 09:56:45
Hello everyone;
First of all, thank you for sharing knowledge about this car. Here I will explain how to connect the original Navi 600 microphone to
the Android radio car
1º Found the original micro.
![[Image: micro1.jpg]](https://preview.ibb.co/dYLgQb/micro1.jpg)
2º. Check the micro color cables:
![[Image: 1.jpg]](https://preview.ibb.co/eWk1rG/1.jpg)
In this case one is blue and the other is brown-black.
3º. Goes to the original bt jack under the radio.
![[Image: modulo2.jpg]](https://image.ibb.co/n7oRQb/modulo2.jpg)
4º. Remove the original bt plug and look for the cables in step 2.
They are two pairs of blue and brown-black cables, check with a tester for electrical continuity to identify the correct ones.
5º With a male-male jack cable , I cutted in one side and the other connect to the radio. Now with the cutted side, connect to the
black-brown and blue cables.
Now it's working the original microphone with the android radio.
Regards from Spain
Regards from Spain
