Navi600
Anyone in or near wiltshire with a navi600?
Navi600
How to use the original microphone Navi600 in Android radio
Hello everyone;
First of all, thank you for sharing knowledge about this car. Here I will explain how to connect the original Navi 600 microphone to
the Android radio car
1º Found the original micro.
[Image:
https://preview.ibb.co/dYLgQb/micro1.jpg ]
2º. Check the micro color cables:
[Image:
https://preview.ibb.co/eWk1rG/1.jpg ]
In this case one is blue and the other is brown-black.
3º. Goes to the original bt jack under the radio.
[img]https://image.ibb.co/n7oRQb/modulo2.jpg[/i
niteram - Replies:
cd400 vs navi600
right then I currently have 2 astra Js
one is a 12 plate (non facelift) 5 door SE with the cd400
other is a 61 plate SRI sport tourer with the Navi600 (with BT and Dab+)
my question regards the audio volume - the CD400 is much louder - does it have an amp or something that the Navi600 doesn't?
and if it does - can I fit one to the Navi600?
any ideas or suggestions??
Cossie - Replies:
cd500 to navi600/900
Would be possible to upgrade cd500 navi to navi 600/650/900 without changing the screen and the buttons and use only the main unit ?
Retrofitting Navi650 from Navi600
I am retrofitting the Navi650 to my parents 63 plate J. I know on other generations of the CD units and some later stuff you could change the VIN in a 256bit eeprom, does anyone know if the applies to the Navi650/950?
I'm not sure if the VIN is in FLASH or EEprom to retrofit it.
Navi600 usb connector
Does anybody know the size of the usb connection that plugs into the back of the radio headunit
milozic - Replies:
Tesla android over NAVI600
Hi, anyone fit the tesla screen with android into car with factory navi600 headunit? any problems?
