How To use Draft posts
[align=center]This is how you use draft post.
Just the same making a new thread or post
1. input the title
2. Type your thread or post
3. Click the "save as draft post" button
4. Click the submit button.
To load your saved post you can click the button that says post with draft post and select the draft post you want you.
Re-input the title and edit away you can re save as draft post if you want or post it.
See video below (will be added once uploaded)
[video=youtube;lsI8_cOZ9Ak]https://ww
WARNING, DO NOT USE, PLEASE READ.
So I purchased a pair of these the other day.
http://www.customled.co.uk/products/canb...-canceller
After fitting both I turned on the car, cleared the errors and both bulbs working, then all of a sudden I see smoke coming out.
Turned the car off and it was one of them on fire,
They were plugged in tightly and the correct way.
Be careful
[Video: http://youtu.be/QuBuUAZBzw0]
[url=http://postimg.org/image/4nq3m6rc
Members use of the forum
Today I have implemented some changes to the forum.
I have removed all additional usergroups and removed the promotions structure for new users.
You are all simply Registered users unless you have paid the membership fee, or made a donation.
If you want to sale an item you need to be a paid member, access to the downloadable how-to's also requires you to be a paid member.
The way guests can view a site has also changed for the better giving them almost the access as a member.
Solder to Use
I don't half feel like I nag on this forum lol. Anyway, I've lost the solder I was using and can't remember what type it was. I've found some lead free solder though and wondering if that's any good for soldering wires together with?
Headlight re-seal what buytl to use ?
Need some info on resealing the headlight back up after installing my projector lens and hid kid do I use the silicone form or double sided thanks
Use SharkFin for GPS/DAB to GPS/FM/AM anubody?
I have purchased the oem sharkfin for GPS/DAB as I have the normal aerial on the my GTC now.
I have bought duppel Fakra connections and extra wires with fakra male/female and connection for GPS aerial on headunit as I have RoadCommander, like Icebox etc., unit instead of the factory CD400. And I want the factory look.
I know on factoty fit navi cars, the FM/AM aeriel was built in the rear tailgate. But that is not an option to make or is it?
[img]http://i38.photobucket.com/albums/e116/Hummel
How to use g4 led instead of t20...
Hello,
I made t20 led using 12v g4 led. The g4 led is used for home lighting. G4 led is 12v and 2 watts. I will try to explain how I do it.
[Image: http://i.hizliresim.com/77ZO9Y.jpg]
I soldered 2 pieces of copper wire to + side. I soldered 1 pieces of copper wire to eksi side.
[Image: http://i.hizliresim.com/l31LkE.jpg]
Then I used the piece of the old t20 LEDs. I connected the positive cables in parallel and there was no error in the car.
[img]http://i.hizliresim.com/VPYAl
How to use the original microphone Navi600 in Android radio
Hello everyone;
First of all, thank you for sharing knowledge about this car. Here I will explain how to connect the original Navi 600 microphone to
the Android radio car
1º Found the original micro.
[Image: https://preview.ibb.co/dYLgQb/micro1.jpg]
2º. Check the micro color cables:
[Image: https://preview.ibb.co/eWk1rG/1.jpg]
In this case one is blue and the other is brown-black.
3º. Goes to the original bt jack under the radio.
[img]https://image.ibb.co/n7oRQb/modulo2.jpg[/i
