fit retro usb factory
USB factory retro fit
[Image: 9nd4_zpsea5fce57.jpg]
...........USB RETRO FIT FOR THE CD 400......
[Image: image_zpsc26af1b4.jpg]
Yes This can and has been Done but Again this is a Very Hard one to Follow and to Do
And this really is a big job you will be removing everything to do this one
your best bet is to get this Done by Someone who knows How Too
Rusty2009 or Vxmods on Here can Supply and Fit the USB for the Factory Retro Fit
But it is Expensive for what it is
Programming and VCI Codes will also be Needed.
Here is the USB and AUX Sockets on the Storage Tray
[Image: 7453bedd-9cc7-49fb-aa49-47585215f67c_zps92d7229f.jpg]
The USB module is located just to the right and above the accelerator pedal
And is held in place by a bracket and one screw.
[Image: 1a6aac55-27aa-4363-acfc-3b747258e015_zpsvzxsnxir.jpg]
Here is a Link too the USB Kit Needed and A How To Fit it Guide
but i do Believe that Two Wires are Wrong in this Guide
It has Something to do with the Audio.
USB Part Number, 13397904.
http://api.viglink.com/api/click?format=...397904.pdf
For this Option The USB Retro fit
I think Money would be Better Spent on an After Market Head Unit,
with USB and Bluetooth, SAT NAV, ETC Combined.
[Image: download%204_zpsjdhqi4gr.jpg]
BUT YES IT CAN AND HAS BE DONE...
[COLOR="#FFFFFF"]Model year from 2013 (13 plate) that has cd400 will not support
any factory retrofits unless the radio has an ident of - UZZ
if usb is already fitted then the radio will support the aditional
Retrofits provididing the radio again is ident- UZZ[/COLOR]
so is it the three part numbers?
13397904
13397905
13437049
is that for all the kit?
i believe so
i know Andy from VXmods has done this
and knows were get the kits etc
as i have not done this he will be the best one to talk to
yep the kit p/no 13397904
thats all is needed but this is not a plug n play kit as
ppl make out, it still has to be configured via a vci
code.
oh and the wiring you get in the kit is wrong to the
instructions and has to be altered.
Big grin
vxmods Wrote:yep the kit p/no 13397904
code.
Big grin
oh lol, you ever in swindon lol
for models before 2012 we also need VCI code?
my 2011 has not needed any yet but others have as i know the VCI was introduced sometime in 2011
but the car still needs activating with a MDI, were are you from
As far as I know anything audio side doesn't need a VCI up to 2012 but for other retrofits VCI'S will be needed.
Most retrofits will require vci code regardless what year the
Car is but also depends how the configuration had been setup
at time of build,usb retrofit definately requires a vci code
As all previous ones ive fitted did require a vci code.
Noooooi believe me ive done so many retro fits on lots
Of the models prior 2012 and most of them needed vci
codes especially the usb retro fit.
But also There has also been many that didnt need vci
codes so it does cone down to how the cars been
configured at time of build.
vxmods Wrote:Most retrofits will require vci code regardless what year the
I have a 2014 plate how do I find out what my radio ident is?
pop the radio out and have a look on it mate
RPO need to be as below pic,
[ATTACH]392[/ATTACH]
WhelanUK Wrote:I have a 2014 plate how do I find out what my radio ident is?
If you havent got any factory options like bluetooth,usb,dab then
id say your Cd400 wont support any of them.
good info there i will add that info into a few how to sections Doublethumbs
but glad i have been there and done all that now Lol
I am in France (Rouen) home opel agent spineless make any changes and still have VCI moin code. it is for her that I ask. so I just add anything because VCI code? unless I come home?
[=MENTION]VXMODS[/MENTION] ANDY will this include the DAB retro fit with cd400 ??
Just a quick question I have one of the Android aftermarket head units, it comes with USB and AUX support. However my Astra J doesn’t come with a USB slot, is there a way to order the tray with the USB slot and just basically plug and play? At the moment the USB wires pushed through into the glovebox.
Yes you can order the tray for under £10 from a dealership & the USB is abit more expensive.
You can run the usb cable under the bubby hole tray and up through the edge and out into the cubby hole, I did it this way for a dab adaptor in our last 5dr J.
https://gyazo.com/8bde8fd24ccad1b9765a778aedf0878a
https://gyazo.com/fbac156e79f48c9e6d7f96dd4d4987da
https://gyazo.com/db255a5c762d390068115efa69a812cd
I got my usb/power/auxin tray off ebay for a tenner. Funny thing is, think I have used the usb slot once in 2 years. The SD card slot on the Android works better with the default music player.
Past 2008 Civic 1.8 Type S
  Factory Reverse Camera, Astra j/GTC, insignia tucpal 29 23,941 12:th-Mar-2023, 15:36:11
  DAB retro fit for cars with the CD 400 tucpal 203 109,241 13:th-Mar-2021, 13:20:56
Last Post: Morpheus75
  DAB retro fit for cars with the cd500 and 600 tucpal 112 206,325 2:nd-Feb-2021, 12:20:02
Last Post: Bernie2021
  POWER FOLD MIRRORS retro fit tucpal 121 87,320 19:th-Jan-2020, 09:18:53
  AUTO DIM ANTI DAZZLE REAR VIEW MIRROR retro fit tucpal 72 48,024 4:th-Aug-2019, 18:26:52
Last Post: KKEVANSKK
andymitchelluk26 (4:th-May-2024, 19:08:47)
