USB factory retro fit
...........USB RETRO FIT FOR THE CD 400......
[Image: http://i179.photobucket.com/albums/w301/...6af1b4.jpg]
Yes This can and has been Done but Again this is a Very Hard one to Follow and to Do
And this really is a big job you will be removing everything to do this one
your best bet is to get this Done by Someone who knows How Too
Rusty2009 or Vxmods on Here c
Retro fitting factory options
Does retro fitting factory options count as a modification?
TPMS (Tyre pressure monitor system)
AFL (Adaptive Forward lighting with Bi xenons)
Both of which make the car safer and I read somewhere that the EU are going to make it compulsory that all new cars have TPMS and Xenon headlamps.
I know it's a modification to the car but they are factory options and all genuine parts have been used rather than aftermarket light units.
Factory Remote Start
Hi All
Was looking around in my settings the other day and I saw "Remote start" in the options.
http://workshop-manuals.com/vauxhall/ast...operation/
I don't believe I have the correct keyfob as the link above says "remote vehicle start buttons"
Any idea if its possible to retrofit / get this working? Would love in the winter months to remote start it!
Factory USB to USB Type A Male
I keep pestering rusty about this and he's probably getting fed up of me! Ha. Also j want to keep as much info here on the forum as possible... So here goes.
Does anyone know how to go about changing the end of the factory USB connector (end that goes into the back to the head unit) to be a USB type A male instead of the vauxhall standard connector? Rusty tried to explain it a bit but I'm still confused [PENSIVE FACE]
Could be as easy as he said which is to cut the factory end off
Factory fitted AMP
Does anyone have the factory fitted amp?
Factory Reverse Camera, Astra j/GTC, insignia
[align=center]NAVI 600, INSIGNIA / ASTRA GTC, FACTORY REVERSE REAR CAMERA, RETROFIT.
FOR THE INSIGNIA WITH NAVI 600 ONLY, from 2010 TO 2013.
FOR THE ASTRA GTC NAVI 600 ONLY, from 2012 TO 2014.
Today i have activated the rear factory reverse camera for the pre facelifted insignia pre 2013
i have activated the factory camera on the navi 600 unit that i have in my 2013 insignia
as you may or may not
Whistle when on a call with factory BT
Anyone else get a whistle when on a call with factory BT?
It's only when the engine is running and it gets louder with acceleration.
I have nothing plugged into the AUX or USB it was fine until a few days just bugging me as I can't find the cause.
Factory Fitted Towbar
My J has the factory fitted removable towbar, I'm pretty sure it was done as new as when the trailer has a light out it displays on the dash.
But I get no audio/visual warning when my trailer is connected and indicators on, a blessing yes as the buzzer is annoying, but as a legal requirement I thought it should have some form of indication.
Any suggestions on whether I should have an extra buzzer/light and why it aint working?
Factory Options List
Hello everyone, so coming from the VW side of things my previous cars had a sticker with the Chassis Number, paint code, and three of four letter codes which listed the options the car had. This was separate from the VIN in the window and was located in the boot or on a rear wheel arch.
I am asking because (Long shot no1 coming) my Sports Tourer appears to have the glass in the rear compartment with the internal antenna for what I hope is DAB, but nothing connected.
So I was in the boot inst
Android RV5754 factory settings password
Hi does anyone know the password?? I have tried 0000 and 8888 as others have suggested but no luck
