USB factory retro fit
...........USB RETRO FIT FOR THE CD 400......
[Image: http://i179.photobucket.com/albums/w301/...6af1b4.jpg]
Yes This can and has been Done but Again this is a Very Hard one to Follow and to Do
And this really is a big job you will be removing everything to do this one
your best bet is to get this Done by Someone who knows How Too
Rusty2009 or Vxmods on Here c
How to hardwire 2 x USB ports into the glove box for dashcam/phone
Afternoon all
As I promised in my welcome thread, thought I would provide a tutorial for adding two powered USB ports in the glove box for powering my dashcam and charging my phone.
Remove Glovebox You will need to do this so follow these instructions.
The kit list I used for this is below
1 x USB Adapter from Ebay (Link to Item)
1 x Pa
USB Port Power Boost
Hey Guys
Anyone know if it's possible to boost the amount of power going to the USB port? My phone charges sooooooo slowly via the USB.
USB DAB & Sharkfin
Well @lewis6317 came down toady for the DAB & USB VCI code to be entered,
[Image: http://i124.photobucket.com/albums/p39/r...ts/Dab.jpg]
[Image: http://i124.photobucket.com/albums/p39/r...ts/USB.jpg]
Also fitted his new DAB DAB+ AM/FM Sharkfin.
[img]http://i124.photobucket.com/albums/p39/rustyw
CD400 Plus USB Help?
Hi guys,
Wondering if anyone can answer a question for me; I drive an Astra GTC with a CD400 Plus unit, I use the USB to listen to music on my phone so I can also use the multifunction controls on the steering wheel to swap songs safely and easily, however, I recently swapped my phone from an iPhone 5 to a Samsung Galaxy S5 and it no longer picks up the phone through the USB. Any advice on how I can sort this?
Factory USB to USB Type A Male
I keep pestering rusty about this and he's probably getting fed up of me! Ha. Also j want to keep as much info here on the forum as possible... So here goes.
Does anyone know how to go about changing the end of the factory USB connector (end that goes into the back to the head unit) to be a USB type A male instead of the vauxhall standard connector? Rusty tried to explain it a bit but I'm still confused [PENSIVE FACE]
Could be as easy as he said which is to cut the factory end off
USB Retrofit kit
Want usb here you go. Full kit with module and looms and the try for it.
£95 posted
Removed as no longer needed, still works. Removed by rusty and can be fitted to you car by rusty
[Image: http://images.tapatalk-cdn.com/16/02/22/...700b08.jpg]
Installing usb port and bluetooth 1.4turbo
Hi I'm after some advice I picked my 13plate astra up today over the moon with it... however I want to know what I need to do and what's the easiest option with regards to getting the bluetooth function working when I press config it doesn't bring up the phone menu so what I'm asking is can I take it to a dealer and they do it or isit just as easy and cheaper for me to do it myself and will it work straight away....... no software changing ect
Also id like a usb port however I'm guessing that m
additional USB plugs on dash
Does anyone have installed additional USB plugs on dash near or instead of cigarette lighter (or in other place)? if you do have it done, can you share some pics and some tips?
i am thinking of having 3 port USB hub connected to Android head unit and have extensions (something similar into the ones from below URLs) comming to center panel with fixed plugs. not sure if that will even work though.. but USB hubs are quite cheap (don't see the reason for usb 3  at least for testing if this would
Best solution for DAB and USB
Hi, guys, I scouted the web and got really confused with the matter.
I have a 2013 Astra J elite with the cd400 and I am looking for a practical solution to fit a USB and if possible a DAB too. USB has the priority.
I was considering an aftermarket head unit but the price is quite high and the car might be sold in 2 year time so something n the cheaper side would be better.
I thought about a Bluetooth car kit but I would like to have full control on the music stored on the phone without h
