5:th-May-2014, 02:00:34
tucpal Wrote:GOING GRATE MATE ABSOLUTELY PERFECT LOVE IT SO MUCH BETTER THAN THE CD400 FOR SURE.
VXMODS
"doing what vauxhall say cant be done"
excellent im glad your happy with it
as title says above
to nav500 cd400 upgrade |
Cd400 to nav500 upgrade.
tucpal Wrote:GOING GRATE MATE ABSOLUTELY PERFECT LOVE IT SO MUCH BETTER THAN THE CD400 FOR SURE. VXMODS "doing what vauxhall say cant be done" excellent im glad your happy with it as title says above
5:th-May-2014, 10:44:47
Great ok!
This eBay one has no wiring loom. Is that a problem? If not I shall buy and let's get this rolling. :-)
5:th-May-2014, 11:35:50
Andy has all that mate.
Just check if you need to get the Nav Shark-fin. Astra-J 2.0 CDTI S/S
5:th-May-2014, 11:50:25
i will sort out the aditional wiring, if your planning
in buying it then ask the seller if he also has the trim insert and the sd card port that its mounted onto.
5:th-May-2014, 19:44:05
I'll send him a message now. Would like to get this.
14:th-May-2014, 22:25:56
hi all
right everyone the retro fit for the navi600 is now a go go if anyone had bought any setups and wants them retro fitting then pls contact me and we sort out booking dates for the installation. i must point out again that when it comes down to the programming procedure then errors have to be expected but im confident these will be resolved. if any setups have been purchased then i can give any guidance as to what cabling is required and must be included when supplyig the setups. cheers.
15:th-May-2014, 06:43:47
Very good to know the nav 600 can be done also very good work Andy top man
15:th-May-2014, 07:35:36
If I could find a cheap setup (the one someone linked sold) I would be interested. But ATM I can't.
15:th-May-2014, 07:36:20
tucpal Wrote:Very good to know the nav 600 can be done also very good work Andy top man yeah it was just the waiting to get an astra booked in for a retro fit which luckily was a gtc that had navi600 so i stripped it a little more
15:th-May-2014, 08:20:46
you have done some real good research in working the nav 500 and 600 out
so to all who said it could not be done yes it can it just needed the wright man,
15:th-May-2014, 08:37:32
tucpal Wrote:you have done some real good research in working the nav 500 and 600 out yeah definately,these particular retro fits do need time in research. i have an insignia booked in that i will be retro fitting the navi600 into in a few weeks that they have been told it wont work so until ive been proved wrong then i have faith that it work perfectly.
24:th-May-2014, 00:10:25
Will the insignia nav800 or nav 600 fit if so it's easier to source
For all your lighting needs click below
www.lushlightingcity.co.uk
24:th-May-2014, 07:23:42
Lush Lighting City Wrote:Will the insignia nav800 or nav 600 fit if so it's easier to source the radio unit and display wud fit but the control facia panel/surround and screen surround from an insignia wont be suitable as there larger. these would still have to be bought seperately so it fits into the astra.
8:th-Jun-2014, 18:05:33
hi all
just an update,the navi600 retro fit to an insignia has been delayed this has now been re scheduled for in a few weeks time,i do have customers queuing up for this retro fit but i just need to complete the first one. if anyone does have the navi600 setup and they want it doin asap then let me know and i get you booked in for the installation. cheers.
15:th-Jun-2014, 13:37:13
Very interested mate, is it the same as you done for tucpal? Now im getting good money in i could do this in july or aug easy :-)
15:th-Jun-2014, 15:18:58
the nav600 is more upgraded than the nav500
but i am not too sure what the difference is really sure someone will tell you the differences.
15:th-Jun-2014, 15:52:15
only difference is the navi600 is sd card rather
than the the navi500 is cd driven.
15:th-Jun-2014, 15:54:58
Lewis6317 Wrote:Very interested mate, is it the same as you done for tucpal? Now im getting good money in i could do this in july or aug easy :-) paul had the navi500 fitted,you have an option to have the navi600 fitted and you have an sd card fitmr the navi instead of a cd like navi500 has.
15:th-Jun-2014, 17:17:06
I was going to ask can you have the radio/cd playing while using the sat nav as my VW is one only which bugs him.
also with the navi600 can't you add speed cams which I don't think you can with the navi500? Astra-J 2.0 CDTI S/S
15:th-Jun-2014, 17:47:28
Yeh navi 600 is alittle better so why not. Plus would give me the usb also right?
15:th-Jun-2014, 17:53:30
Rusty2009 Wrote:I was going to ask can you have the radio/cd playing while using the sat nav as my VW is one only which bugs him. yes you can use the navi while you use the cd player, what you do it save the navi software from the cd to the head unit and then you can remove the navi cd and play cd's as normal.same applies with the dvd800 but with the navi600 you have a sd card for the navi which you dont remove and the cd player is free for the cd's not too sure on the speed cans for either of them
15:th-Jun-2014, 17:54:20
Lewis6317 Wrote:Yeh navi 600 is alittle better so why not. Plus would give me the usb also right? yes all navi units come with usb as std
15:th-Jun-2014, 18:06:09
vxmods Wrote:yeah thats it thanks m8 Does this include bluetooth???
15:th-Jun-2014, 18:13:52
Cameron UK Wrote:Does this include bluetooth??? nope all prices quoted in me trader section are for individual retro fits.
16:th-Jun-2014, 08:10:42
It's well worth it mate loving the car now with the nav500
16:th-Jun-2014, 08:46:02
tucpal Wrote:It's well worth it mate loving the car now with the nav500 is indeed a good upgrade. p.s. paul i need a chat to you so can you give me a buzz laters when you get 5 mins
16:th-Jun-2014, 10:32:04
Text today or I can speck tonight mate
15:th-Oct-2014, 14:53:44
I have a 10 plate elite with CD400 no Bluetooth DAB or USB
I have bought navi600 with complete wiring harnesses of a 13 plate and Finn also got Bluetooth module is there a guide to fitting please or can I arrange with you (vamos)to fit
15:th-Oct-2014, 15:19:30
andy from vxmods will sort it were are you and i will send him a message for you
15:th-Oct-2014, 18:08:53
I'm in Milton Keynes
15:th-Oct-2014, 18:57:46
Cheers pal
15:th-Oct-2014, 20:01:31
No contact yet
16:th-Oct-2014, 09:05:23
kuda81k Wrote:No contact yet pm sent.
17:th-Oct-2014, 16:54:50
good luck hope you get it done it is well worth it
and keep us all updated thank,s.
24:th-Dec-2014, 02:16:32
Bringing this back to life - I am very interested in getting this done some time early new year. Im in Preston so Is it far i'd have to travel to get it fitted? How long does it take? This sounds like an awesome upgrade for my SRi 2010!
Vauxhall Astra J/Mk6 SRi VX-Line 1.6 Turbo 5-door
Mods to date: VXR 18" alloy wheels wrapped in Bridgestone Potenza S001 225/40/R18 tyres - K&N Panel filter - Pipewerx Custom 3" stainless steel cat-back (with 2nd cat removal) exhaust system - Rear window tints - EBC Grooved front 300mm brake disks with yellowstuff road/race brake pads - Xenon/LED DRL full headlight conversion - Full leather - Custom ADE Tuning dyno remap 245.9bhp / 280lb-ft
21:st-Sep-2015, 21:32:29
(24:th-Mar-2014, 09:43:30)tucpal Wrote: Basically cars from 2009 to 2012 per face lift don't need VCI codes, so they will not be a problemHey mate, Does this still apply for earlier models? I have a 2011 2.0 CDTI SRi and i keep looking for a deal for bluetooth or ideally sat nav. what worries me is vci codes, but just wondering as mine is 2011 do i not need to request codes from vauxhall? cheers Tony
22:nd-Sep-2015, 07:23:33
Lewis's 60 plate needed VCI codes.
22:nd-Sep-2015, 07:32:11
Ah bugger, not sure if there's anyone near me able to do it :/
22:nd-Sep-2015, 09:06:48
And my 60 reg has not needed any pot luck really but some time during that reg it was introduced you wont have any problems even if a vci is needed
22:nd-Sep-2015, 15:15:58
My 61 plate which was registered 31/12/12 needed a VCI code for DAB
22:nd-Sep-2015, 16:21:01
61 plate could be registered up until March time I believe.
4:th-Feb-2016, 14:44:19
(22:nd-Mar-2014, 20:44:10)tucpal Wrote: Who can do this for me please if you say what to get I will get all parts needed. Thanks in advance.
4:th-Feb-2016, 14:45:38
Hi who can do this for me ? Thanks in advance
4:th-Feb-2016, 18:45:01
At the minute it's proving quite difficult GM have tightened up and getting codes for the navi is proving hard.
We thought we found a workaround but these leads to other issues no parking sensors steering wheel controls etc. Astra-J 2.0 CDTI S/S
4:th-Mar-2016, 00:27:49
How can I contact Andy from vxmods?
Need a navi 600 putting in my 2012 insignia it's currantly got a cd 400 in it I have this Arial head units ect just need him to install it for me cash waiting |
Stereo upgrade options | Amazingusername | 6 | 10,522 |
9:th-Feb-2021, 14:07:41 Last Post: loeb |
Upgrading the CD400 | sadiqr10 | 0 | 3,698 |
11:th-Nov-2020, 04:58:09 Last Post: sadiqr10 |
Cd400 software update | Lukedent1234 | 8 | 9,358 |
21:st-Sep-2019, 10:00:32 Last Post: Rusty2009 |
cd400 quality | rbull51 | 9 | 12,251 |
24:th-Aug-2019, 18:02:12 Last Post: niteram |
Wanting to install bluetooth and upgrade CD400 | andy2174 | 14 | 29,570 |
1:st-Mar-2018, 20:27:35 Last Post: marcus01 |
HID upgrade | Dale90 | 29 | 15,665 |
10:th-Aug-2017, 09:33:25 Last Post: Dale90 |
CD400 reception problem | MDS2017 | 3 | 8,095 |
3:rd-Mar-2017, 21:00:27 Last Post: GOKIWI |
ECM "Upgrade" Recall Causing Performance Issue? | Black_Cat | 4 | 6,177 |
6:th-Nov-2016, 22:57:55 Last Post: Rusty2009 |
Shark fin for cd400 | chrisb2511 | 10 | 31,485 |
10:th-Aug-2016, 07:21:51 Last Post: Rusty2009 |
Washer jet upgrade / change? | rbull51 | 1 | 4,641 |
27:th-Jul-2016, 22:58:36 Last Post: Rusty2009 |
Who read this thread? |
7 User(s) read this thread: |
Michal Zabka (18:th-Dec-2023, 09:50:51), airainchoc (25:th-Jun-2023, 17:10:24), milozic (21:st-Sep-2023, 19:17:49), James37518 (16:th-Jan-2024, 17:35:43), Farkask14 (25:th-May-2023, 17:17:06), ynns (18:th-Jun-2023, 18:30:54), giderci (28:th-Feb-2024, 15:09:17) |
