problem reception cd400
CD400 reception problem
Have 2014 Astra SRi fitted with non-DAB CD400 radio. Am getting split second breaks in transmission when using the BBC channels (no problems on local radio settings). Use mostly Radio 1, 2 and 4. Dealership suggest it is to do with transmitters. Based in Buckinghamshire, but also occurs out of area. Any suggestions welcomed that might remedy this.
It could be the aerial the radio unit the transmitters so many factors at play, it may pay to contact a car audio company.
(3:rd-Mar-2017, 18:57:21)Rusty2009 Wrote: It could be the aerial the radio unit the transmitters so many factors at play, it may pay to contact a car audio company.
Aerial has been changedat dealers without making any improvement.
I had a similar issue, unscrew the aerial give the threaded part a good clean (I used brake cleaner not WD40) no issues since. Unfortunately same issue in my Kia, the aerial is fixed :-(
  Cd400 to nav500 upgrade. tucpal 265 435,084 31:st-Aug-2021, 19:57:38
  Upgrading the CD400 sadiqr10 0 5,457 11:th-Nov-2020, 04:58:09
Last Post: sadiqr10
Astra 1.7 CDTI fuel quality problem klajdi 0 4,308 10:th-Sep-2020, 12:10:05
Last Post: klajdi
  Injectors or SCV problem? kartush45 1 4,988 11:th-Mar-2020, 11:08:58
  Cd400 software update Lukedent1234 8 15,306 21:st-Sep-2019, 10:00:32
  cd400 quality rbull51 9 19,079 24:th-Aug-2019, 18:02:12
  Electric Window intermittent problem Stanhope 3 7,694 21:st-Mar-2019, 14:35:49
Last Post: Stanhope
  Astra J self starting problem Jopo2311 8 8,935 16:th-Mar-2019, 10:29:33
  Help-2012 Astra J S model rear window demister button problem irishastraowner 14 19,636 26:th-Sep-2018, 23:50:59
Last Post: everson38
  Wanting to install bluetooth and upgrade CD400 andy2174 14 38,046 1:st-Mar-2018, 20:27:35
