update cd400 software
Cd400 software update
Hi I have recently been having problems with my Cd400 unit it hasn’t been picking up all the dab stations, it find them when saved but didn’t have any reception to them and I can’t find the station list, I spoke to a service tech at Vauxhall and he said I need to do a software update, dose anybody know where I can get this update as he said I have to download it to a usb but can’t find it anywhere
There is no USB update for the CD400 nor the DAB module & even if there was you wouldn't find it floating around the internet as it would have to be downloaded via SPS.
So what are the issues you having a stations not storing or no DAB signal?
It’s just not picking up certain station on dab gets most of them but the ones I use don’t seem to work no more will have a word with Vauxhall’s again tomorrow and see what they say
Hi there has recently been an update to the DAB network, radio stations saying if you do not have DAD+ you need to retune?
I have done a retune and updated the stations but still nothing from them
Well I haven’t been able to do a retune as I do not have a option for that however the station was working I went in to the shop and when I can back it hasn’t worked since
I had to re select my stations as I listen Gold (amongst others) and they have changed their frequency,
Gold no longer broadcast on DAB only on DAB+
There are a quite a few now which have moved to DAB+ away as cheaper for them than DAB.
https://en.wikipedia.org/wiki/List_of_ra...)_stations
How Do I get dab + then is it possible or am I just going to hve to live with out the stations
You can get a DAB+ module (U4D)
The main radio may need reprogramming so it can enable DAB+ although in most cases it doesn't.
  Cd400 to nav500 upgrade. tucpal 265 422,009 31:st-Aug-2021, 19:57:38
  Upgrading the CD400 sadiqr10 0 5,306 11:th-Nov-2020, 04:58:09
Last Post: sadiqr10
  cd400 quality rbull51 9 18,560 24:th-Aug-2019, 18:02:12
  Technical Service Bulletin 3141 ECU update Tony Davis 2 6,380 4:th-Feb-2019, 15:15:49
Last Post: Tony Davis
  Wanting to install bluetooth and upgrade CD400 andy2174 14 37,025 1:st-Mar-2018, 20:27:35
  2.0cdti ECU update for DPF causing poor fuel & loss of performace Rusty2009 17 26,130 23:rd-May-2017, 07:00:23
  CD400 reception problem MDS2017 3 11,321 3:rd-Mar-2017, 21:00:27
Last Post: GOKIWI
  Shark fin for cd400 chrisb2511 10 36,343 10:th-Aug-2016, 07:21:51
  Navi 600 Firmware Update C0ntax 2 9,589 11:th-Jun-2016, 11:58:04
  EPB update tucpal 17 26,695 12:th-Sep-2015, 09:49:55
