Update on lights and grill
As you some of the brackets on my lights are broken! Today I drove from Leeds to Manchester to pick up some new lights (2nd hand £150), got there after confirming over the phone that they were 100% perfect to find numerous brackets broken.
I've now ordered some fixing kits for the lights (13335737) which I'm going to be fitting Saturday! Might do a how to or maybe someone will post the link to the workshop instructions below
I've also got a new lower grill to fit so a how to might
ongoing problem UPDATE
So I've still got the ongoing problem with the SVS light coming on. It's been in vx the last 2 days and they think they have found the problem, apparently pin 24 is broken on the esc connector, this is apparently causing my problems with the clutch switch! It's costing £288 as hey say this must have been caused when the repair was done to my car when it was in its accident. They also said there is now no error codes, does this sound viable? I'm just worried incase the light comes back on, what
dtuk box aftre softwhere update
Any one had any problems after software updates
Mine seams down on power
But drives ok
Tapatalk update
Just updated tapatalk to the newest version so if there are any problems let me know thanks.
Sat nav Update info
Sat Nav update discs.
When purchased they are sold as Hardware and Software.
The hardware is the update of the Sat Nav, A New Firmware version.
The Software is the Map Program itself.
How to install a Map Update (The manual isn't clear on this and no instructions are given with the disc)
1. Insert the New Map CD into the CD player.
2. The screen will show that there's an update for the firmware.
3. Click Install.
4. It will ask if you wish to over write the Flash in the memory, click okay to do
EPB update
just had a service update for the EPB hill start assist done today
they said it has just come out this week
this is to make the hill start assist less likely to kick in on smaller slopes when really it is not needed
apparently after lots of complaints about it coming on when stopping on uneven ground
so keep an eye out for that one
Site update 1st/May/2016
Navi 600 Firmware Update
Is it possible to do a firmware update on Navi 600 and if so how? I've got a 2013 GTC and wonder if it's been updated since. Can't find any info anywhere.
2.0cdti ECU update for DPF causing poor fuel & loss of performace
So when my car had Turbo issue's the dealership did a software update to the ECU.
This update is related to the DPF
Quote:It adjusts the parameters for the dpf temperature sensors to improve dpf performance and avoid overloading dpf, eml lights and in worst cases engine stalling.
it's a software weakness that only effects astra j, cascada and zafira tourers up to model year MY13.5. The update will just adjust the software weakness that is present.
At first I didn't notice
re: recent update
Hi i have recently updated my software from navi 600 to 900. My question is when i am buying a new map is it the 600 card i need still?
Thanks in advance
Lee Lamont
