light air bag passenger
Passenger Air Bag Light
This is illuminated when the daytime running lights are on, if I switch the normal lights on it goes off,  is this correct?
DP
What do you mean? The orange light comes on when you turn the ignition on and then go after a few seconds
(8:th-Jan-2016, 21:45:23)bhalay207 Wrote: What do you mean? The orange light comes on when you turn the ignition on and then go after a few seconds
Yes,  and stays on as it states in the hand book to show the passenger air bag is activated.
When the main lights are switched it it goes dimmer not off like I originally thought.
Oh ok. Have you deactivated the airbag? Check the switch on the edge of the dashboard as you open the drivers door. You need to put your key in it, push in and twist in the necessary direction
(8:th-Jan-2016, 22:37:39)bhalay207 Wrote: Oh ok. Have you deactivated the airbag? Check the switch on the edge of the dashboard as you open the drivers door. You need to put your key in it, push in and twist in the necessary direction
No,  the air bag is active which is the default position unless you need to put a child seat in the passenger seat you then have to de activate it.
It states if the air bag is de activated then no passengers are permitted to occupy the front sear.
  New AutoDipDown module for passenger mirror A20DTH 2 5,337 21:st-Oct-2022, 09:33:44
Last Post: rlievens
  Coolant light coming on when coolant is full (new sensor and no leaks) baffling me! Brasseyebaby 3 8,185 2:nd-Feb-2021, 21:12:47
  Electric passenger window not working Harposaurus 2 6,165 30:th-Sep-2020, 19:29:35
Last Post: Harposaurus
  passenger door deadlocked celrx 3 6,046 15:th-May-2020, 15:29:46
Last Post: paula9568
  DPF REGEN LIGHT Starie 113 148,539 19:th-Apr-2020, 21:00:20
Last Post: Multiskilled
Spanner Light illuminated with engine off Wwood1991 2 5,976 11:th-Feb-2020, 13:01:57
  Rear Light Replacement (Need Advice) A.ROD 2 7,549 17:th-Dec-2018, 19:17:48
Last Post: A.ROD
  Headrest for middle rear seat passenger benawhile 7 10,219 12:th-Oct-2018, 07:10:57
  Help engine light Mspencer 12 17,206 18:th-Mar-2018, 17:17:36
Last Post: Mspencer
  No wiring for the interior boot light marcus01 5 9,295 20:th-Dec-2017, 16:48:23
Last Post: rlievens
