Is anyone coming to Bournemouth for the air show
How to stop Smelly air-con
I can't take the praise for this one as such, although mine is slightly different to the how to guide available elsewhere on the Internet.
Here goes: For a few months I have had a bad smell from the air con after it has been turned off, especially the day after. I understand this to be a build up of bacteria within the system, but I hadn't realised how cheap and easy it is to resolve.
Firstly, buy a can of this [ATTACH=CONFIG]242[/ATTACH] which cost me £3 from Asda. I understand it has been
How to remove air vent trim
sheppy1 - Replies:
Air Vent Trim
Is anyone selling the trim from round both the driver and passenger side air vents?
Bournemouth air show meet
Would anybody be interested in a club meet at Bournemouth to coincide with the FREE Bournemouth Airshow?
I would need to speak with the local council as it will be very busy and they shut a lot of roads off.
The air show is on 20-23 August.
www.bournemouthair.co.uk
If interested pop your name below.
tucpal - Replies:
HOW TO TOP UP AIR CON.. ASTRA J
[align=center][Image:
This How to Covers How to Top up the Air Conditioning on the Astra J/GTC.
You can Buy Air Con kits from Halfords or Online there Basically all the same
The Kit cost is Around £60.00 with the Charger Adapter and the Top up Canister
You can Get £10.00 Back on the Canister after use so after Purchasing the Charger Adapter
The Next Time you Top up it will only Cost £30.00 for the Canister
The Charger
tucpal - Replies:
PIPER CROSS AIR FILTER
DaPa - Replies:
Passenger Air Bag Light
This is illuminated when the daytime running lights are on, if I switch the normal lights on it goes off, is this correct?
DP
Air filter K&N
So my air filter arrived today, I took my factory one out and tried to fit the new one... For some reason the new one is more rectangular than the factory one which is totally square... So it wouldn't fit! Have they sent me the wrong one?
Ta
MAF Mass Air Flow Sensor is this common problem
Hi Guys,
[b][color=black][size=medium][font=Tahoma, sans-serif]i just wanted to know ,if the MAF Mass Air Flow sensor is a common fault to go on these 2011 Astra, as my car since the I had this warning sign Diesel Partic Filter is Full Continued Driving Mandatory and then emissions control fault light appeared on the screen. I had a service indicator illuminated even though i had the service done recently, but this
