squeaky clutch door clicking and drivers
Clicking clutch and squeaky drivers door
I looked through the other threads and couldn't see anything in relation to this other than the squeaky clutch.
My clutch when it's engaged clicks near the top of the decompression. So basically you press it slightly and then it clicks once as you press it down fully.
The door squeaks, it doesn't rattle, it squeaks when the the road is slightly bumpy and I can't pin point it for the life of me, I pressed/hit every part of the door card and it wouldn't stop, any ideas?
Door could be the hinges or the catch.
Clutch may just need a bit of grease.
(6:th-Jan-2016, 22:45:22)Nemo Wrote: I looked through the other threads and couldn't see anything in relation to this other than the squeaky clutch.
I think my car does this. When I go round a corner, it's almost like the door is flexing and creaks
I don't think it's the door hinges, I had a closer listen today and it came from where the locking pin is (the thing that goes up and down when the door is locked and unlocked)
  Drivers Heated seat turning off JohnL 111 133,661 3:rd-Mar-2020, 16:35:35
Last Post: RobD67
  Sinking Clutch Pedal t1mj1m 3 7,774 2:nd-Nov-2019, 10:23:40
  Noise when clutch 1/4 depressed 2013 Astra J Galway11 0 10,578 27:th-Jun-2019, 22:40:04
Last Post: Galway11
  squeaking clutch peddle tucpal 10 22,664 18:th-Dec-2016, 20:13:20
Last Post: panelman
  New clicking noise richje100 7 12,373 29:th-Sep-2014, 21:36:45
Last Post: Cameron UK
  Squeeky clutch Cameron UK 1 6,072 15:th-Apr-2014, 22:51:02
