Drivers Heated seat turning off
Had this on my Elite it ended up having the pad replaced. When switched on they would work for about 2 minutes and then turn off. However if you put them on a lower heat setting they would stay on longer.
Anyway the VXR has started this morning. Heated seat works for 30 seconds no matter which heat setting you have it on. I've seen some people mention that there is a bulletin regarding the wiring loom when they have had the same issue. Does anyone know if this the case or not?
Clicking clutch and squeaky drivers door
I looked through the other threads and couldn't see anything in relation to this other than the squeaky clutch.
My clutch when it's engaged clicks near the top of the decompression. So basically you press it slightly and then it clicks once as you press it down fully.
The door squeaks, it doesn't rattle, it squeaks when the the road is slightly bumpy and I can't pin point it for the life of me, I pressed/hit every part of the door card and it wouldn't stop, any ideas?
Sent from my iPhone us
Drivers door glass removal
Hi can anyone recommend here give me a full guide to remover the glass as much info as poss please thanks ks in advance.
led courtesy light drivers door
So got my new GTC today, this evening noticed that just the passenger courtesy led light works, the gator light either my old j 5 door had a gator light. i presume there is one for the driver door.
[Image: https://i.ytimg.com/vi/X-bbbR_CiF4/hqdefault.jpg]
Drivers door speaker
Anyone got a standard door speaker going spare for the drivers door
Phil
Drivers side complete suspension leg
Hi i am after complete suspension leg for the drivers side.
my car is 2015 astra GTC Limited edition.
Leave a comment and il get back to you ASAP!
Squeaky drivers window
My drivers window is very squeaky when I lower/raise it. Feels like its rubbing on something.
Any possible causes or remedies that would fix this please.
Strange feeling when testing foot in drivers footwell
So when driving I rest my foot on the rest bar & every know and then I can feel the steering wheel through it (sounds daft but I genuinely can) the steering wheel also makes a weird sound occasionally like a piece of leather being twisted.
Only done this since a mate changed my oil filter by just jacking the car up & going in via driver side wheel.
Think he's knocked something?
GTC 1.6T Drivers Information
Just bought a 2013 GTC 1.6T but the Drivers Information Centre isn't as detailed as the 1.4T I test drove previously. Are the additional features only available on the 1.4 or can they be activated on the 1.6 also.
Thanks in advance
Rear Seat Belt Buckle-Drivers Rear-Single
Hi guys,
Im after a Rear Seat Belt Buckle please, I dont know if I have got the naming correct, but its basically what the rear seat belt plugs into.
I only need the single one, which is driver rear.
My car is a 2011 Elite, so dont know if its different on the other editions.
Many thanks.
