pedal clutch sinking
Sinking Clutch Pedal
Any ideas. My 1.3 cdti clutch pedal sinks about half of it's travel when left overnight. I have had the master replaced but still does it. If I pull it back up it works fine for the rest of the day car has 63k miles on it. It's going back for slave oh! and the fluid level doesn't drop either (so no leak). Thanks in advance for any help.
I had the same problem on my 2.0 cdti, it was still under used car warranty and I had the entire clutch replaced inc master & slave cylinder, dmf, clutch plate and pressure plate and it didn't cure it, it turned out to be a broken pedal spring on the pedal shaft. I understand its a bit of a pig to replace but mine has been fine since.
That does make sense.
there is a chap selling a metal version on ebay for £40.
  Noise when clutch 1/4 depressed 2013 Astra J Galway11 0 8,048 27:th-Jun-2019, 22:40:04
Last Post: Galway11
  squeaking clutch peddle tucpal 10 17,392 18:th-Dec-2016, 20:13:20
Last Post: panelman
  Clicking clutch and squeaky drivers door Nemo 3 10,726 8:th-Jan-2016, 20:49:23
Last Post: Nemo
  Brake pedal vibration richje100 25 16,704 18:th-Jan-2015, 12:59:02
Last Post: kevinn
  Squeeky clutch Cameron UK 1 3,849 15:th-Apr-2014, 22:51:02
3 User(s) read this thread:
livo (8:th-May-2023, 11:04:28), geoffsnook (6:th-Jul-2023, 19:17:48), exhippykev (22:nd-Jun-2023, 21:50:50)
