New clicking noise
Anyone throw any ideas at me.
My brakes are noisy so I'm going to change the discs in a few days.
But when I stop driving forward and reverse say onto my drive when I brake I hear a click like something has become unstuck.
Only happens when I reverse from moving forward and only does it once.
Doesn't do it when I go from reverse to forward but when I reverse again.
I've take the wheel off to see if the disc plate is rubbing or the pads not sitting right but seems ok.
Anything to look for when i
Nemo - Replies:
Clicking clutch and squeaky drivers door
I looked through the other threads and couldn't see anything in relation to this other than the squeaky clutch.
My clutch when it's engaged clicks near the top of the decompression. So basically you press it slightly and then it clicks once as you press it down fully.
The door squeaks, it doesn't rattle, it squeaks when the the road is slightly bumpy and I can't pin point it for the life of me, I pressed/hit every part of the door card and it wouldn't stop, any ideas?
Sent from my iPhone us
Nemo - Replies:
Clicking clutch
Every time I decompress the clutch, it makes a noticeable clicking sound as if it's metal on metal. You can feel in as you press it and hear it too. It happens just at the start of the decompression too.
Anyone know if a bit of grease will sort it or is it an underlying thing that a mechanic needs to look at?
Strange Clicking Noise Astra J?
Hi, on cold morning my astra J 1.7 110 2010 has a squeak which goes after 5 minutes or until warm then after the squeak has quietened you can hear this strange clicking tapping noise only when lights, radio on etc like its coming from the alternator which is still original but giving good reading on battery and charge?
Link to video
https://youtu.be/KRxgX4q-ckU
Clicking noise
ive got a clicking noise when i hit the throttle pedal and the turbo kicks in.the clicking noise is for a second or two.
some times i hear it some times not.it happens when i accelerate hard and it seems to be coming from the engine bay or underneath that area.cars fine otherwise.
anybody got any ideas what it could be.
DOOR CHECK STRAP STOP FRONT RIGHT Making clicking noise
hi Guys,
I am having noise on the driver side door and it is making clicking noise. Do I need to replace it or I can twist and remove it
(4:th-Aug-2019, 19:56:56) caretaker Wrote: hi Guys,
