door alignment of out
Door out of alignment
Hey guys!
Just have a question about an issue I noticed a few weeks ago before I went on holiday. I've noticed that the passenger side door no longer sits flush with the body of the car (photos attached). I can push the door and it then sirs flush but as soon as I let go it pulls away from the car again.
Any ideas what could have caused this and how I can fix if?!
[Image: 757d0fc7ea4c1834ecb76c9528540ccf.jpg]
[Image: a229721469414829b73fe43a245d5358.jpg]
To fix it, loosen the part of the catch affixed to the car body (not the door) knock it in a few mm and tighten, repeat if still not far enough. Hope that makes sense ha
No idea what could have caused it though
Cheers! I kind of know where you mean, I'll grab a photo of what I think you mean and if that's correct then I'll sort it at the weekend least it sounds like an easy fix!
Ok pal ill keep a look out for it, its a 5 min job
I actually have no idea which part it is haha
Here's a photo of the door open, can you specify which bit is the catch?
[Image: f9a92492a2d1c40d582fdfb9d7cc3ce3.jpg]
Its the small catch on the other side on the car body not the actual door just lose it off and move it back
Hmmmm THINK I know what you mean, lemme have a look tomorrow
Mad busy this weekend so can not send pics it the small silver door catch that the door locks into on the car body
http://youtu.be/0k8Q6m0qNug
Doubt you need to replace yours but that's the part
@sheppy1 it's the part that rusty brought covers for. Looks like a silver U shape
Yeah think I know which bit you guys mean now! Just a little bit of metal that the door hooks onto when it's closed isn't it?
(5:th-Sep-2015, 06:59:53)dutton84 Wrote: http://youtu.be/0k8Q6m0qNug
That video is spot on! I'll check the metal thing on mine this morning! Thanks
There will be little marks above and below the catch just move it back a notch and then try the door till it fits
You guys were spot on! The bottom screw on the door catch thing was loose so it was wobbling around and not holding the door firmly enough when closed.
Tightened the screw and it's all good now! Thanks a millions guys
Good effort mate!
(5:th-Sep-2015, 11:40:05)tucpal Wrote: There will be little marks above and below the catch just move it back a notch and then try the door till it fits
Did just that mate! Saw those little marks and lined them up as you said, all good now
Cool well done
  Vxr bumper on 5 door Astra j Sh4rk2007 10 15,111 6:th-Jun-2021, 18:25:04
  Diesel door wont opel Arkanggel10 2 4,232 13:th-May-2021, 15:31:33
Last Post: Arkanggel10
  door drain grommets bigbadkes 2 4,855 28:th-Aug-2020, 19:45:49
  1.6 cdti 5 door exhaust tip? h4r7y 1 4,710 17:th-Jul-2020, 06:47:38
  passenger door deadlocked celrx 3 6,006 15:th-May-2020, 15:29:46
Last Post: paula9568
  Door locking Flick19191 1 3,681 22:nd-Nov-2019, 09:40:18
  Replacing door check strap robk999 5 10,596 7:th-Feb-2019, 21:27:33
  Astra J 5 door facelift bumpers Iaintruten 5 8,224 30:th-Oct-2017, 16:40:35
Last Post: Iaintruten
  5 door drl to led rfoster88 3 8,229 3:rd-Oct-2017, 16:58:03
Last Post: rfoster88
Smile Astra J 5 door Facelift diffuser MandaJ88 0 5,938 27:th-Sep-2017, 13:14:37
Last Post: MandaJ88
