to box ports usb hardwire the dashcam x into 2 for how glove phone
How to hardwire 2 x USB ports into the glove box for dashcam/phone
#51
There are two fuses
Fuses 6&7? Checked them both and replaced them both
some power sockets have 3 wires but yours has 2
i dont have the handbook anymore at hand but you need to read all fuses and look anything eles linked to the others
I bet there's nothing. I'll pull every fuse out and check them
I think that's your best bet mate. I've just looked at the manual and it only says about 6&7
(15:th-Mar-2016, 22:04:44)bhalay207 Wrote: I think that's your best bet mate. I've just looked at the manual and it only says about 6&7
Yeah I've looked at mine too, only mentions the two, 6 for front and 7 for rear. Neither are working and I've replaced the fuses for them. I'm so confused and stumped. I even undid everything that I did in the first place too
Is it an option you could have fried the wiring or the 12v socket itself? Or would something like that also have triggered the fuse to blow?
Sent from my Vodafone Smart ultra 6 using Tapatalk
The fuse would have gone. I've not introduced any more current though
Check fuse 16 in glovebox and fuse 17 in rear fusebox if fitted
Checked 16 previously and it's fine, not done 17 @cornishtaz
What about that blue plug that goes into the back of the socket... Did you remove that when doing the work? If so did you put it back in the correct way?
Yeah it only goes one way
Also the manual mentions fuse 26 in glovebox
26 is for if he doesn't have a box in the back isn't it?
"Power outlet load compartment (if no load compartment fuse box) (Sports tourer only)"
Best will be to pull them out 1 by 1 and check them
Checked all fuses, they're all fine, replaced the relay switch for the 12v sockets and it's still not working
I'm stuck
Have you tried taking negative off battery for 15mins? Maybe worth a try??
(18:th-Mar-2016, 12:36:55)Tonto Wrote: Have you tried taking negative off battery for 15mins? Maybe worth a try??
Tried it, had it off for a few hours
Hmm very strange mate, I've just ordered the things I need. I can't be bothered with having this sort of problem.
(18:th-Mar-2016, 12:40:52)Tonto Wrote: Hmm very strange mate, I've just ordered the things I need. I can't be bothered with having this sort of problem.
You'll be fine if you do it my way and not whatever random way @nemo did it
That is true
Cheers for the vote of confidence haha
Oooo burn 😬
@Nemo do any of your power outlets work?
This may help
(25:th-Mar-2016, 20:53:04)cornishtaz Wrote: This may help
I wish that made sense to me lol.
Dust off the old engineering degree @tonto and get to work
Haha I guess so @sheppy1 I'm doing my dash cam and dual USB socket tomorrow, didn't get chance on Wednesday!
Ahhh was gonna ask you about that the other day! Sure you'll have no issues mate top mod as I say and looks factory fitted!
Yeah I can't wait, I had a couple errands after work and didn't get round to it, had the bairn lastnight as Mrs was at work and to it I've not been bothered haha
Yeah they all work now @cornishtaz but thanks anyway, also my camera isn't usable in USB mode as it think I'm plugging it into a computer when I do that
What was the issue @Nemo
Well I didn't have a multimeter so I went and bought one and it turns out the adapter had blown for the cam
So you didn't try the socket with other devices to make sure it wasn't just the camera charger?!
I did, I had one other and I must have blown it too
What are the odds of that eh! glad it's sorted though
That's madness. At least it's working now.
I've come across this while looking at a new cam
https://www.ebay.co.uk/ulk/itm/131528446842
(11:th-Apr-2016, 14:57:04)Rusty2009 Wrote: I've come across this while looking at a new cam
What cam are you thinking of mate?
I have 0805 already for the front so looking at getting another for the rear or getting the update 0903
Not heard of the 09** version. I can highly recommend my 'wedge' cam for being discreet
Sent from my Samsung Galaxy Tab S 10.5
Farkask14 (26:th-Nov-2023, 14:28:14)
