How to hardwire 2 x USB ports into the glove box for dashcam/phone
Afternoon all
As I promised in my welcome thread, thought I would provide a tutorial for adding two powered USB ports in the glove box for powering my dashcam and charging my phone.
Remove Glovebox You will need to do this so follow these instructions.
The kit list I used for this is below
1 x USB Adapter from Ebay (Link to Item)
1 x Pa
Where to earth hardwire kit
I have bought nextbase hardwire kit and manage to to slip the wire behind both wires and air bag in the A frame of passenger side. (Not strong enough to pull the A Pillar trim fully with that metal clip in place).
I have threaded the wire down the inner door by removing the rubber sill and was going to the side where the fuse box in the glove compartment.
My question ... should I attach the earth (black wire) to a metal bar behind the glove box on one of the nut bolt (not sure if it
