to remove vent air trim how
How to remove air vent trim
So start by getting a trim in the bottom and then slide it across.
Now with a slight rocking of the trim tool the fascia will start to pop off work you way along the bottom then up the right side and stop by the top.
Move the trim tool to the left side and again using a rocking motion the fascia will pop off
On re fitting you must start at the top as you place it in there will be a slight gap, all you do is then push upwards and the top will click in then then do each side then the bottom.
excellent how to and well done.
Thank you! AGAIN!!!
No problem
good tut mate
just be real careful they are brittle
but this is well worth doing if you are going for a color change on the trim.
I cant get it off
I tried with 3 different tools and always i get under the trim but then i go under the black plastic...
Any pointers?!
Thanks!
Only real pointer is not to stick in too far and you need to have a slight angle.
Yeah not many tips to give! Just gotta use a thin tool and make sure you don't prise it too hard as I managed to break a bunch of clips when I did it
Thanks,
tried again and managed - final tool Bacho knife
Hi guys I'm a newbie so please be patient I wanna carbon wrap all the chrome in my astra any help would go along way thanks
  How-to Remove Airbag Steering Wheel & Buttons Rusty2009 49 45,291 9:th-Sep-2020, 00:40:49
Last Post: M222RJF
  How-to remove Instrument Cluster (IPC) Rusty2009 24 40,117 23:rd-Jul-2020, 11:21:25
Last Post: scrooge
help with interior A trim removal passenger pillar astra j stestrange82 3 6,961 20:th-Feb-2019, 13:45:22
  How to remove the center console & EPB switch tucpal 11 24,484 4:th-Feb-2019, 02:38:22
Last Post: DikoAJ
  How-to Remove Sun visors Rusty2009 10 20,160 25:th-Aug-2018, 21:40:03
  How to remove door cards Rusty2009 112 83,755 9:th-Aug-2018, 09:57:13
Last Post: DNT
  Howto remove glove box & Replace Pollen Cabin filter tucpal 43 47,573 18:th-Apr-2017, 05:33:21
Last Post: iphoneservice
  How to stop Interior Trim Rattles from Passenger side area Astra J. tucpal 9 20,529 3:rd-May-2015, 17:42:49
  How-to Remove Door Trim Rusty2009 1 10,226 15:th-Mar-2015, 13:31:07
