Trade Count:
( 2)
Threads: 220
Thanks Received: 1 in 1 posts
Thanks Given: 0
15
Sex: Male
Total Feedback: 0
13:th-May-2015, 19:05:40
(This post was last modified: 4:th-Nov-2016, 13:12:44 by tucpal.)
HOW TO FIX HEATED SEAT PROBLEMS AND REPLACE THE SEAT COVER.
This How to will Cover How to Fix the Heated Seat from Intermittently Dropping out and Cutting off
This is a Big Job but Easy when you know How.
The main Problem is a Bad Connector to the Seat Heating Control Module
This over Time will Burn the Resister out in the Bottom Seat Heating Mat
So the First Fix will be to Replace the Connector to the Seat Heating Control Module
With a Reworked Connector that you can get as a kit from Vauxhall at a Cost of £27.50
GM Part number for the kit is 13442703.
In the kit you will get a New Connector and 6 Wires with Pins Attached
so the First Thing To Do is to Remove the Seat from the car.
.......... Stage one ....... SEAT REMOVAL .........
Disconnect the Main Connector from under the Seat
then Remove the Two T50 Bolts from the Rails at the back of the Seat
Push the Seat up and Pull it Back to get the Seat out from the Car
then Turn the Seat on its Side and Remove the Plastic Cover
For the Seat Belt Presenter use a T50 Socket and Remove the Bolt
Then Under the Seat Unclip the Yellow Connector and take the Seat out.
........... Stage two ............. REPLACE THE CONNECTOR ON THE MODULE .............
Disconnect the Center Connector on the Seat Heating Control Module
Strip the Loom Tape Back and Cut the old Connector from the Loom Make a Note of what Color Wires
Go too in each Position on the Connector add the New Pins to the New Connector in the Correct Positions
Then Join the Wires back Together making Sure you have some Slack on the Cable and Re Wrap with Loom Tape and Reconnect.
This is the First Thing to Try as This is the Course of the Fault
You can Replace this Without Taking the Seat out of the Car
if this Does not Work then the Next Step is to Replace the Bottom Seat Heating Mat.
............... stage three ........... REPLACE THE SEAT HEATER MAT ..............
......step one.......
Start at the Back of the Seat and Pull the side Covers apart Left and Right
Then Pull the Bottom Cover apart and undo the small Connector at the Bottom of the seat.
.....step two....
Next Start at the Seat Belt Side of the Seat and Remove the Two Screws
From the Plastic Cover and Remove it from the Seat.
......step three......
On the Other Side of the Seat Starting at the Rear of the Trim Remove the Cover from the Lever arm
you just need to lift it out with a Blade but Do Not Remove this Lever Arm
Next the Center Lever Arm after Removing the Cover take the Screw out
and Remove the Lever Arm Then you will see a Screw Hole in the Trim Remove that Screw
Next Remove the Cover from the Front Lever Arm and Remove Two Screws and take the Lever arm off
Then Remove one Screw from the Rear Trim and one Screw from the Front Trim
Gently Pull the Trim back a bit and Unplug the Connector for the Lumber Support Button.
The trim will not come off Completely but this will give you enough Access to get to the bits you need to.
......STEP FOUR.....
At the Back of the Seat Pull the Three Tabs on the Seat Cover Down and off the Small Metal Bar
Then turn the Seat over the Remove the Four Hog Rings on the Leather Straps Cut the Hog Rings with some Wire Cutters
and Pull them off with Some Pliers be Careful not to Damage the Leather Straps .
......STEP FIVE....
Start to Remove the Trim Around the Bottom of the Cover that Attaches too the Seat Frame
Then Turn the Seat over and Pull the Cover out and then Pull the Foam out Also.
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
15
Sex: Male
Total Feedback: 0
14:th-May-2015, 09:38:18
(This post was last modified: 16:th-May-2015, 10:42:27 by tucpal.)
..............STEP SIX.............
Next Remove the Two Screws From the Seat Heating Control Module
Then Remove Four 8mm Bolts that Hold the Seat Extension in place
Then you can Remove the Seat Cushion From the Frame.
......STEP EIGHT......
Remove the Seat Cover from the Cushion.
Turn the Cushion over and you will see 3 Bars with Hog Rings on them Remove these Rings
IMPORTANT ALL THE HOG RINGS ON THE CUSHION NEED TO BE CUT OFF NOT PULLED OFF
THE METAL FRAME THEY ARE ATTACHED TO IS SET IN THE FOAM AND OVER PULLING THE RINGS WILL RUIN THE SEAT.
Next turn the Cushion over Start at the Back Lift the Cover up and you will see more Hog Rings on a Bar
again Cut the Rings off and the move to Each Side of the Cover and Cut more Hog Rings from the Sides
then you will see the Center Bar again Remove the Hog Rings
after that again Remove the Remainder of the Hog Rings from Each Side.
........STEP NINE......
Remove the Remainder of the Cover from the Seat Extension
Start at the Side and Work your Way Around
You have now Removed the Seat Cover and you are Ready to Replace the Seat Heater Mat.
....STEP TEN.....
Seat Heating Mat Replacement
The Seat Heating Mat Costs £88.50 and the Part Number you will Need is
GM 13257326.
Start to Gently Peel the old Heater Mat from the Foam
Take your Time and Try Not To Ruin the Foam
After you have Removed the old Heater Mat
start to Add the New Heater Mat by Removing the Backing Tape
and Sticking the New Pad in Place.
.....STEP ELEVEN......
REFIT THE SEAT COVER.
Start with the Seat Extension First and Reattach the Cover
Then move on to the Front Hog Bar you can use Hog Rings if you wish but you will need a Special Tool
As i Do not have one i have use Zip Ties But keep the cut ends facing down not up
Again WARNING Take Care with the Metal Bars in the Foam Do Not Pull on Them to Hard
Start at the Front Bar Then the Sides Then the Middle Bar and then The Sides and Then the Rear Bar
You can then Pull the Cover over the Foam and Start to Refit the Seat Cushion to the Seat.
And that is it all Done This may Seem like alot of Work but this is the Fix
To get the Seat Heating to stop Cutting Out if your Car is under Warranty then Take it Back and Keep on at Them
To get it Fixed as this is a Know Fault.
This Cost Around £120 to Fix if you Tackle it Yourself
And This is Well Worth the Effort as Vauxhall Dealers Charge £120 just to Change the Connector
And Anywhere up to £400 to Change the Seat Heating Mat
Simply Swapping the Seat over to Solve this Problem may not be the answer
As this is a Very Common Fault and the other Seat may Have the Same Problem
This is a Common Fault Across the Range and Effects the Astra j, Insignia and Moka
Hope this will help someone out there.
Trade Count:
( 4)
Threads: 359
Thanks Received: 8 in 8 posts
Thanks Given: 1
73
Sex: Male
Total Feedback: 0
Very good mate glad you fixed it now.
That should help alot of people.
I'm also glad mine was done under warranty.
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
15
Sex: Male
Total Feedback: 0
Trade Count:
( 0)
Threads: 200
Thanks Received: 0 in 0 posts
Thanks Given: 0
6
Car: Astra J 1.7 CDTI
Sex: Male
Total Feedback: 0
Bloody hell!!!! That is a bloody big job!!! Haha, well done on doing the tut and getting it sorted...no way in hell I'm doing this with mine haha...would sooner buy a new seat than do all that :P. Not that I'm lazy, I just don't trust myself and without a garage and also needing my car to get to work, I couldn't be without it if anything went wrong
Trade Count:
( 2)
Threads: 3
Thanks Given: 0
3
Car: Vauxhall
Sex: Undisclosed
Total Feedback: 0
Great how too. Is the pad and connector on the back of the seat different?
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
15
Sex: Male
Total Feedback: 0
yep but the problem is the bottom pad
Trade Count:
( 0)
Threads: 0
Thanks Given: 0
0
Car: Astra
Sex: Male
Total Feedback: 0
Just join the forum as was looking for a solution to the problem of the heated seat cutting off, mine has just started doing it, and it's the same as other's on the forum, it's the drivers side. Glad I found this forum as might try changing the connector, do not know if I would attempt the pad change. Was pretty impressed with the how to that was posted best I have seen.
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
15
Sex: Male
Total Feedback: 0
try the connector first as this is the route cause of the problem
and that will need to be done either way to stop it recurring in the future
then if that does not solve the problem then the heater pad is the next step
if you have any warranty take the car back and let them know this is a know problem
and you want it fixed if you have no warranty your on your own with this fix
but the good news is it does work and will not happen again when it is done
Trade Count:
( 1)
Threads: 16
Thanks Given: 0
0
Car: 2.0 CDTi Elite
Sex: Male
Total Feedback: 0
Can confirm warranty best option if you have it, I have just had mine done 3 weeks ago and its working perfectly now. Would have cost £350 otherwise from the dealer....
Trade Count:
( 0)
Threads: 0
Thanks Given: 0
0
Car: Astra
Sex: Male
Total Feedback: 0
(12:th-Nov-2015, 19:04:21)tucpal Wrote: try the connector first as this is the route cause of the problem
Trade Count:
( 0)
Threads: 0
Thanks Given: 0
0
Car: Astra
Sex: Male
Total Feedback: 0
Might sound a stupid question but if I try changing the connector does the battery need to be disconnected, or can it be done without disconnecting it.
Trade Count:
( 0)
Threads: 21
Thanks Given: 0
0
Car: 1.7td Elite 2010
Sex: Male
Total Feedback: 0
I've been plagued with my drivers seat heating problems for three years roughly, having been back to the dealers a few times. They replaced parts galore for me and worked for a while but now it cuts out within a minute. After that, no matter how far I drive, I am turning it back on every two minutes. You can hear a 'click' under the drivers seat and then you watch the heated seat button on the dash to go off within two seconds. I am sick to the back teeth of it.
Anyway, my point is this (and not wanting to sound picky here by the way)....there was no mention of the heated seat contrl module being faulty in your how to guide. Can we 100% rule that out as being the faulty part?
Fantastic write up and pics by the way!
Cheers, Graham
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
73
Sex: Male
Total Feedback: 0
When mine was done under warranty vauxhall replaced both pads,and the module. Only problem I find no is there seem to be no safety cut off and the seat will just get hotter and hotter.
Trade Count:
( 0)
Threads: 200
Thanks Given: 0
6
Sex: Male
Total Feedback: 0
such an odd issue! luckily mine isn't TOO bad...on full heat it cuts off after about 4 mins but then I can press it again and it will then last another 4 mins...if I select a lower heat level though it will stay on forever.
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
15
Sex: Male
Total Feedback: 0
The how to will fix it do the wiring then the lower pad job done pian in the but to do but it will work after it has been done
Trade Count:
( 2)
Threads: 57
Thanks Given: 0
0
Total Feedback: 0
Well my car has had the fix and guess what happening again:-(
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
73
Sex: Male
Total Feedback: 0
(23:rd-Nov-2015, 20:35:15)Lewis6317 Wrote: Well my car has had the fix and guess what happening again:-(
Take it back then mate.
Trade Count:
( 2)
Threads: 57
Thanks Given: 0
0
Total Feedback: 0
24:th-Nov-2015, 17:42:03
(This post was last modified: 24:th-Nov-2015, 17:42:18 by Lewis6317.)
I have and still waiting if they will sort it or not without paying
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
15
Sex: Male
Total Feedback: 0
24:th-Nov-2015, 21:18:40
(This post was last modified: 24:th-Nov-2015, 21:20:05 by tucpal.)
i really only have the heated seat now on setting no3 till the seat gets hot
then i turn it down to no2 or off as leaving it on setting no3 all the time will only lead to problems
on the astra j before i did the fix i am sure the problem starts with excessive use of setting no3 on constant or for long periods of time
then the heater pad just over heats as rusty says there seems to be no heater pad temp control at all on setting no3
i had no problems after the fix at all but i did alter how i use the heater controls as well
and i still do with the insignia setting no3 to get the seat hot then turn it down to setting no2
or setting no1 this should prolong the life of the heater pads.
Trade Count:
( 0)
Threads: 19
Thanks Given: 0
0
Car: Astra J Vx-Line
Sex: Male
Total Feedback: 0
25:th-Dec-2015, 23:54:18
(This post was last modified: 26:th-Dec-2015, 00:04:17 by Nemo.)
@tucpal if you don't mind me asking how much did it all cost?
Ignore this, I didn't see the prices in the tut
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
15
Sex: Male
Total Feedback: 0
THINK IT WAS £30 FOR THE KIT AND ABOUT £70 FOR THE HEATER PAD
AUTO VAUX SELL THE BOTTOM PADS
Trade Count:
( 0)
Threads: 19
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
Cheers buddy. If the dealer won't touch it I'll do it myself. The car is exactly what I want so I can't walk away from it
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
15
Sex: Male
Total Feedback: 0
it looks harder than it is it just takes i bit off time but just take your time and follow the how to and you will be fine
looking forward to seeing what you have got
Trade Count:
( 0)
Threads: 19
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
Thanks aha, I'm sure I'll manage it. But we'll see. I'm currently looking for a flat bottomed steering wheel, and I can't find one anywhere
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
15
Sex: Male
Total Feedback: 0
they do turn up but when they do jump on them
Trade Count:
( 0)
Threads: 0
Thanks Given: 0
0
Car: astra H
Sex: Male
Total Feedback: 0
a great find, and how to, and it will help a lot of people
can i ask something about the connector? you write that it is the main cause of the malfunction
and i would like you to tell me if possible (and if you know) is it the connector it self? or the wires? what i mean if i keep
the existing connector and change the wires and pins with new one will it work? or do i have to change all of it?
thank you for the reply
postscript
i am not a car electrician i only want to help friend who has the same problem
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
15
Sex: Male
Total Feedback: 0
gm part number GM 13442703
Trade Count:
( 0)
Threads: 0
Thanks Given: 0
0
Car: astra H
Sex: Male
Total Feedback: 0
(31:st-Jan-2016, 12:33:31)tucpal Wrote: gm part number GM 13442703
yes i did see the part number at the beginning of the thread but the question is
if we do not buy the replacement from opel can we use the same plastic connector of the car
and just replace pins and cables with new ones?
will this work? or not?
is the new plastic connector some how different from the old one?
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
15
Sex: Male
Total Feedback: 0
31:st-Jan-2016, 23:03:39
(This post was last modified: 31:st-Jan-2016, 23:04:07 by tucpal.)
it looked different as it was green and white thats all i know
Trade Count:
( 0)
Threads: 0
Thanks Given: 0
0
Car: astra H
Sex: Male
Total Feedback: 0
Trade Count:
( 0)
Threads: 7
Thanks Given: 0
0
Car: astra j gtc
Sex: Male
Total Feedback: 0
Tucpal your seats are the agr?
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
15
Sex: Male
Total Feedback: 0
Trade Count:
( 0)
Threads: 7
Thanks Given: 0
0
Car: astra j gtc
Sex: Male
Total Feedback: 0
1:st-Feb-2016, 19:00:33
(This post was last modified: 1:st-Feb-2016, 19:08:07 by gsisr.)
https://www.youtube.com/watch?v=bPXnL6ZhGmY i'm trying to understand if there is a difference to the agr seats
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
73
Sex: Male
Total Feedback: 0
Agr is the trim level of the seat IIRC
Trade Count:
( 2)
Threads: 57
Thanks Given: 0
0
Total Feedback: 0
god I need to do this on my car again.... As vauxhall want £100 more this time :( so not impressed
Trade Count:
( 0)
Threads: 0
Thanks Given: 0
0
Car: Astra j
Sex: Male
Total Feedback: 0
I got my plug and wires for 30.00 posted form here
http://www.genuinepartsearch.co.uk/ The dealers was 42.00
Trade Count:
( 0)
Threads: 0
Thanks Given: 0
0
Car: Astra j
Sex: Male
Total Feedback: 0
I got mine for £30 posted from http://www.genuinepartsearch.co.uk/ it was £42.00 from dealers
Trade Count:
( 0)
Threads: 0
Thanks Given: 0
0
Car: Astra J
Sex: Male
Total Feedback: 0
I had mine done under warranty 3 months back. The problem has started again but only worse. When I press the button for the seats it will turn off after a minute.
Sick and tired of this now and VX should address this issue as a lot of users are having problems
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
15
Sex: Male
Total Feedback: 0
Did they replace the seat mat and do the fix for the module also
Trade Count:
( 0)
Threads: 0
Thanks Given: 0
0
Car: Astra J
Sex: Male
Total Feedback: 0
(25:th-Feb-2016, 00:34:37)tucpal Wrote: Did they replace the seat mat and do the fix for the module also
Hi mate,
no they just did the mats as far as I know. I will let them now that there is a problem with the module.
Have you had the issue come back since you fixed yours?
Trade Count:
( 2)
Threads: 57
Thanks Given: 0
0
Total Feedback: 0
I have had the matts replaced last year and the issue has come back for me. I had to pay aswell, yet they will not do anything unless i pay more and fit it yet again.
Trade Count:
( 0)
Threads: 0
Thanks Given: 0
0
Car: Astra J
Sex: Male
Total Feedback: 0
(25:th-Feb-2016, 10:42:34)Lewis6317 Wrote: I have had the matts replaced last year and the issue has come back for me. I had to pay aswell, yet they will not do anything unless i pay more and fit it yet again.
Seems like an issue with most users. Vauxhall need to sort it out as this is clearly a problem for all. I bought the car purely for the leather seats as they were heated but I cannot use them as intended
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
15
Sex: Male
Total Feedback: 0
there seems to be a lot of confusion with the dealers on this fix
they should start at the curse of the fault first the plug then the fix the mat
my fix did last a good year and was still working fine when i sold the car on
if they just replace the mat the problem may or will happen again
but that said it is very poor design fault after all so they should just man up and get them all redone
Trade Count:
( 0)
Threads: 57
Thanks Given: 0
4
Car: Astra J SRI 2.0 CDTI
Sex: Male
Total Feedback: 0
(25:th-Feb-2016, 16:01:54)tucpal Wrote: there seems to be a lot of confusion with the dealers on this fix
but that said it is very poor design fault after all so they should just man up and get them all redone That's manufacturers for you. They don't want to get anything done unless their hand is forced!
Trade Count:
( 0)
Threads: 21
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
I followed the above guide and have to say it to be absolutely spot on after much mulling over whether or not to do it or not. Took around 4 hours to replace the bottom seat pad but I did take things easy so as not to damage anything. After all that, it turned out to be the bloomin' connector (after spending £109 on the seat pad) as I was convinced this had been replaced by VX twice before while under warranty. The connector cost me £45 from Arnold Clark VX at Northwich and after 20 minutes driving the heated seat has stayed on (not done this for moons). A 90 miles round trip tomorrow should confirm everything is OK but I'm confident. Great write up by Tucpal and saved me a wallet full of cash by not going to the stealership.
Trade Count:
( 0)
Threads: 200
Thanks Given: 0
6
Sex: Male
Total Feedback: 0
4:th-Apr-2016, 18:33:20
(This post was last modified: 4:th-Apr-2016, 18:39:00 by sheppy1.)
How do you replace the connector mate?! I'll try that to see if it fixes mine
Never mind I'm thick and didn't read the tutorial! Ha. So did you just cut the connector off and replace with a new one?
Trade Count:
( 0)
Threads: 21
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
Sheppy, I've pm'd you but if you follow the above 'how to' then its easy enough once you get your head under the seat and strip back some loom tape. The hardest part is to loosen the (T55 I think) 2 Torx bolts holding the seat to the floor. I snapped 2 socket adapters in the process.
Trade Count:
( 0)
Threads: 200
Thanks Given: 0
6
Sex: Male
Total Feedback: 0
Cheers mate! I replied to you, Oh and also I found that I get the following DTC error code when the heated seats cut out:
B1925 05 or B2170 05
The temperature sensor voltage is greater than 5 V for more than 1 second.
Does anyone know if this points to anything specific being the fault?
thanks
Trade Count:
( 0)
Threads: 200
Thanks Given: 0
6
Sex: Male
Total Feedback: 0
The plot thickens!!! According to the DTC codes definitions that @rusty2009 posted on here, the error I get is for the passenger heated seat (of which I don't have):
Passenger Heated Seat Cushion Temperature Sensor Signal B2170 02 B2170 05 B2170 05 B2345 13
