power lighter replace outlet cigarette
Replace cigarette Lighter/Power outlet
Hello
my dshcam plug has broken off flush with the power outlet socket (just the spring loaded metal connector)
I cannot seem to get it out, any idea easiest way to get to the outlet (Fuse 6 I believe) and repair/replace it ?
Many Thanks
I'll double check mine as it's out ATM but sure there is some slots on the back you can push it out that way.
(25:th-Jul-2017, 07:19:21)Rusty2009 Wrote: I'll double check mine as it's out ATM but sure there is some slots on the back you can push it out that way.
Cheers Rusty I didn't see any slots , so be interested in what you can tell me
  HOW TO FIX HEATED SEAT AND REPLACE SEAT COVER ASTRA J tucpal 78 121,884 13:th-Nov-2019, 09:49:21
  Howto remove glove box & Replace Pollen Cabin filter tucpal 43 67,644 18:th-Apr-2017, 05:33:21
Last Post: iphoneservice
