amp p0087 fault codes p0399 cylinder astra malfunction 1 2 2011 pressure circuit
Astra 2011 2.0 Fault Codes - P0087 & P0399 - Cylinder 1 Pressure Circuit Malfunction
Have the 'Service Soon' message popping up intermittent on my Astra J 2001 2.0 Diesel, and the fault codes read are:
P0087 - Fuel Rail - Too Low Pressure - Unrecognised State
P0399 - Cylinder 1 Pressure Sensor Circuit - Malfunction - Faulty Function
The car  seems to drive OK, no general loss in power but am noticing when changing gears the engine revs seem to overun if the gas is less off when the clutch is down.  i.e. if chaning at 3,000 rev, and i put the clutch down and let off the gas, the 3,000 revs is maintained for a few seconds and not inline with letting off the gas.  Not sure if this is linked.
Any advise in tracking down the issue appreciated!
These cars do hold the revs for gear changes.
Is there any byte code to go with them codes?
P0087 = https://workshop-manuals.com/vauxhall/as...p0088_lbs/
P0399 = https://workshop-manuals.com/vauxhall/as..._or_p03bb/
Also we have quite a long list already made for errors.
https://www.vxoc.org.uk/forum/Thread-Fault-Codes
Thanks will have a look there, I am guessing Glowplug 1 may need replacing and hopefully that sorts
I unfortunately dont have any byte codes :(
  Astra j sport settings change!! blacknik 5 9,605 13:th-Dec-2018, 20:17:47
  How to Astra gtc 2.0cdti sound loud and good Silvaw07 1 9,199 30:th-May-2018, 09:57:07
Last Post: Andy1874
  P0128 Fault code chris_yorks 3 10,004 12:th-Jul-2017, 06:42:00
  My fault codes J1ODYA 5 13,446 11:th-Feb-2017, 20:19:24
Last Post: Sc0tty05
  Astra j wheel nut thread sizes Azza1807 3 12,077 16:th-Sep-2016, 20:25:31
Last Post: stigeye
  Astra J Wheel PCD Chrissyf 1 9,416 5:th-Sep-2016, 06:52:36
  Fault Codes Rusty2009 11 95,377 9:th-Apr-2015, 09:52:50
  owners manuals. astra j, astra gtc tucpal 2 17,826 18:th-Feb-2015, 08:31:35
  Option / Equipment Codes Rusty2009 1 16,095 17:th-Feb-2015, 03:00:21
  Paint Codes Rusty2009 2 18,392 9:th-Mar-2014, 09:53:51
BryanRIX (9:th-Feb-2025, 04:27:04)
