Malfunction Indicator Light on after adding oil
Hello everyone,
My remaining oil life showed 22% (I have plenty of time till my services) and I've decided to add some oil.
I bought the right one and added about a liter of oil.
I thought that the percentage would change upwards, but it didn't. So I tried resting it. Now it shows a 100% but the MIL light is on.
I read a bit online and found out that in order to really reset it, you must press the brake pedal.
[i]Manual Oil Life System Reset
1. Turn on ignition.
2. Push Menu button
2016 Astra K GTC Malfunction Light Question
Hi Everyone
I could do with some advice to help with an issue that has just surfaced.
I started my Petrol GTC this morning (27/10/2018). The warning lights came on as normal and then all went our except for the Yellow Engine Warning Light. This light stayed on. The car seems fine to drive. It has done 13,010 miles, had a full service 4 months ago and has been sitting in the drive for the last 3 weeks doing nothing while I recover from an operation. The oil level is fine. I have checked and
"Electronic Stability Control System" & flashing "Malfunction indicator light"
When driving last night i got the "electronic stability control & traction system" symbol when is staying constant.
Today it appeared again AND a flashing "malfunction indicator light" also appeared. The cars power was restricted.
Its a 2012 1.4 petrol. The car is misfiring a small bit.
Can anyone advise the problem?
Aftermarket headunit malfunction
Anyone there having similar problem.
I had recently installed rear view camera that fits where the rear light is, just above the number plate (Astra elite 2011). All wires set up and camera triggers on when in reverse gear.
The problem - the button on the car stereo faceplate (Volume and option) & steering wheel control works perfectly prior the use of rear camera. Once I active the rear camera via the reverse gear the screen views the rear and after disconnecting the reverse gear the cam
Astra 2011 2.0 Fault Codes - P0087 & P0399 - Cylinder 1 Pressure Circuit Malfunction
Have the 'Service Soon' message popping up intermittent on my Astra J 2001 2.0 Diesel, and the fault codes read are:
P0087 - Fuel Rail - Too Low Pressure - Unrecognised State
P0399 - Cylinder 1 Pressure Sensor Circuit - Malfunction - Faulty Function
The car  seems to drive OK, no general loss in power but am noticing when changing gears the engine revs seem to overun if the gas is less off when the clutch is down.  i.e. if chaning at 3,000 rev, and i put the clutch down and let off the ga
