fault my codes
My fault codes
Thanks Rusty, op-com bought and plugged in... but these are my codes:
[Image: 20161002_162300_zps56xsoawk.jpg]
Most pressing is the top but suspect dodgy glow plug based on it just being serviced.
Any ideas about the rest?
P0672
P0513 I get it on mine at times I just clear it.
B0014  Could be a broken wire a bad contact etc etc.
B0955
B0956 (as above)
Hope they help abit.
Hi Rusty,
Yeah I did some googling and came up with them results to however thanks for taking the time to reply.
I'll get it in a garage to replace the glow plug and hope that sorts.
I'll investigate the airbag one myself.
As for sensors I've had some repair recently so wonder if they nicked the wires or something, I'll test if they work right and if so just clear the codes.
Great bit of kit though this op-com. Thanks for the details.
Where do u get the code reader/software?
Sent from my Pixel XL using Tapatalk
(10:th-Feb-2017, 18:31:39)Sc0tty05 Wrote: Where do u get the code reader/software?
http://www.op-com.co.uk/store/p7/Latest_...stage.html
Cheers for that
  Astra 2011 2.0 Fault Codes - P0087 & P0399 - Cylinder 1 Pressure Circuit Malfunction coalfield 2 10,087 5:th-Oct-2020, 23:21:12
Last Post: coalfield
  P0128 Fault code chris_yorks 3 10,965 12:th-Jul-2017, 06:42:00
  Fault Codes Rusty2009 11 98,866 9:th-Apr-2015, 09:52:50
  Option / Equipment Codes Rusty2009 1 17,289 17:th-Feb-2015, 03:00:21
  Paint Codes Rusty2009 2 19,497 9:th-Mar-2014, 09:53:51
