Paint Codes
[Image:
paint name,....... paint type,..... paint code.
BLACK PEARL.... PREAL... TACW
myth green,.... Pearl,..... 30/GAY.
METRO BLUE,.... Met,........ 168/GBI.
Flaming Yellow,....... Brilliant,....... 40Q/AJU.
TECHNICAL GRAY,....... Met,.... 177/GAL.
Fresh Mint,....... Met,..... 30Q/GOK.
Iceberg,...... Pearl,..... 21Y
Option / Equipment Codes
[Image:
[align=center]
RPO - Description
UDB - DISPLAY INSTRUMENT - DRIVER INFO ENHANCED (SEGMENTED)
UDC - DISPLAY INSTRUMENT - DRIVER INFO ENHANCED (ONE COLOUR GRAPHIC)
UDK - INFOTAINMENT DISPLAY - COLOUR INFO DISPLAY (CID) 7", QVGA
UEC - SENSOR INDICATOR - AUTOMATIC AIR RECIRCULATION
UFD - INFOTAINMENT DISPLAY - TIME, EXTE
Fault Codes
[align=center][Image:
Fault Codes
Diagnostic Trouble Code (DTC) List - Vehicle
This master DTC list includes all applicable (B) DTCs in alphanumeric order with descriptors.
[TABLE=]
[TR]
[TD]
DTC [/TD]
[TD]
DTC Descriptor [/TD]
[TD]
Diagnostic Procedure [/TD]
[/TR]
[TR]
[TD]B0000[/TD]
[TD]Vehicle Speed Information Circuit Invalid Data.........Vehicle S
Torque APP Error codes
does anyone know what 'fuel system monitor bank 1 min 10,432minute max 40,992minute current 6,624 minute' means???
J1ODYA - Replies:
My fault codes
ABS sensor/ fault codes
Had service ESP warning light come on, the TC light and ABS light came on.
I've had the codes read, one was drivers side front ABS wheel speed sensor and the other was for ABS pump.
Got both cleared and esp warning came back on straight away from leaving the garage, I have changed the sensor now and had 4 hours of warning light free driving today [Image:
https://www.vxoc.org.uk/forum/images/icons/thumbsup.png ].
However the ESP warning has come back on, I've not had it back to have the
Astra J Cutting out - no codes
I have an Astra J 2011 - 1.4 Petrol and currently have an issue with it losing power & cutting out intermittently. Have had the AA out twice to get me restarted, first time they replaced coil pack, for it only to cut out again, replaced coil pack with original and it started and ran fine to get me home. Second time they just unplugged coil pack and plugged it back in and car started immediately. Have taken the car to two different garages and neither have found any fault codes or anything logged
Opcom Fault Codes
Hi everyone,
Just to give some background on why I decided to purchase an OpCom reader, I've been having the following issues on my J GTC 1.4:
Strange limp mode without warning lights/messages (accelerate to a certain RPM in a certain gear causes it to lose around 60% of power. It goes back to normal if I restart the car)
Cold start higher revs than normal - needle ticks past the 1k RPM range for a couple of minutes and then lowers to a normal rate
Starting the engine af
Fault codes
Hi guys any help will be appreciated.. What are these codes for?
Astra 2011 2.0 Fault Codes - P0087 & P0399 - Cylinder 1 Pressure Circuit Malfunction
Have the 'Service Soon' message popping up intermittent on my Astra J 2001 2.0 Diesel, and the fault codes read are:
P0087 - Fuel Rail - Too Low Pressure - Unrecognised State
P0399 - Cylinder 1 Pressure Sensor Circuit - Malfunction - Faulty Function
The car seems to drive OK, no general loss in power but am noticing when changing gears the engine revs seem to overun if the gas is less off when the clutch is down. i.e. if chaning at 3,000 rev, and i put the clutch down and let off the ga
