fault code p0128
P0128 Fault code
Hello all and thanks for reading this.
Daughters GTC has P0128 fault code and A/C off due to high temp with fan running on full speed & temp gauge on dash not moving above 50 degrees.
New thermostat fitted - (old one was passing a little when cold)
Symptoms the same.
Looked at the service manual pages - should I now be looking at replacing another sensor in the radiator?
Many thanks.
http://workshop-manuals.com/vauxhall/ast...de_or_llu/
(11:th-Jul-2017, 07:37:56)Rusty2009 Wrote: http://workshop-manuals.com/vauxhall/ast...de_or_llu/
Thanks for all help.
After a couple of journeys  with a new thermostat, the fault cleared. I did read somewhere that this my take a few drive cycles to resolve.
Yes it can take up-to 50 cycles without the fault being present before it deletes it from the system.
  Astra 2011 2.0 Fault Codes - P0087 & P0399 - Cylinder 1 Pressure Circuit Malfunction coalfield 2 10,067 5:th-Oct-2020, 23:21:12
Last Post: coalfield
  P0128 2 weeks after replacing temp sensor JonathanLondon 4 12,784 5:th-Aug-2020, 23:39:02
Last Post: JonathanLondon
  My fault codes J1ODYA 5 14,658 11:th-Feb-2017, 20:19:24
Last Post: Sc0tty05
  Fault Codes Rusty2009 11 98,797 9:th-Apr-2015, 09:52:50
  RPO Code List Rusty2009 4 17,006 20:th-Apr-2014, 20:32:37
