to led lights smd upgrade interior how
how to upgrade interior lights to SMD LED
This is a very Simply and Cheep Upgrade
How to Upgrade interior Lights to SMD LED BULBS.
STEP ONE..........
Start with the sun Visors all you need to do is to Remove
the two Plastic pieces to get Access to the Bulbs
Gently Pull from one Side
and swap the Bulbs for the New SMD LED.
Now your Girl Friend will be very Happy
as she now has Super Bright white SMD LED'S to do her Makeup.
STEP TWO............
Remove the Trim from the Console in the Headliner.
Pull off the Trim around the Light Unit.
Then you need to Pull off
the Plastic light Cover.
You can Add your New SMD LED Bulbs
i went for one Red in the Center
and Two white each side
but you can do what you what.
RESULTS..........
And here is the Results.
STEP THREE........
Is to Remove the Plastic Cover
from the Rear Lights in the Headliner
again this will just Pull off.
RESULTS...........
And the results..
The SMD LED,S are much Brighter
than the Standard Bulbs
and they look much Better
make sure you Get Canbus Error Free Bulbs
there are Plenty of ebay Listings for these Bulbs now
and Typically you can get them all for under £15.
You are Looking for W5W/501.SMD, LED, Bulbs x 5
and 6615F are the Standard sun Visor Bulbs
you will need x4 SMD LED,S
You can also swap the Glove Box Light to SMD LED
just Remove the Glove Box.
How to Here..
http://www.vxoc.org.uk/forum/Thread-Howt...bin-filter
that just need 1 x w5w/501 SMD LED.
ALSO CHECK AT BOTTOM OF THE PAGE FOR A BETTER LED BULB OPTION...POST 21..
are mate nice i been looking to see what bulbs i need for inside to make them ice white
found the kit on ebay only £13 for them all
also lush lighting city are now a member on here
they do all the led,s you will need
if you contact them they can also help
with the best led smd to use.
already swap mine bulbs to leds.
much better
Can someone send me a link to the full set I need to upgrade,
Cameron UK Wrote:Can someone send me a link to the full set I need to upgrade,
Its in the bulb thread mate.
I'm wanting to buy a full set, I've bought some 501 SIDS but don't think they are canbus free
I want a full set of canbus error free lights for sun visors, front reading lights, rear all in one set
here are the bulbs you need
VAUXHALL ASTRA J GTC VXR INTERIOR LIGHT UPGRADE KIT WHITE BLUE RED CANUBS x6 Led | eBay
i will get the link for sun visor led,s later.
Can I just say, you don't need to remove the glove box to change the glove box bulb, I will do a how today or tomorrow when I get my car back p
tucpal, is that link for the for the sun visor
No mate I will add one for them tomorrow
here you go these are the ones you want.
ASTRA J ASTRA GTC SUN VISOR VANITY MIRROR BULB LED UPGRADE KIT XENON WHITE CANBU | eBay
Changed all mine today, got the led's from Lush
Lighting, only the glove box bulb to change now
cool well done there much better and well worth doing
oweh Wrote:Changed all mine today, got the led's from Lush
Don't forget the boot, cheap 501 are perfect! I've got them in the front lights, rear lights, give box and boot
Kool :-)still looking to get some the hard ones to get are the sun visor bulbs
Get them from Lush Lighting mate
Yeh am waiting for sunvisor bulbs to be instock
does anybody have a link to the bulbs that are send to outside the uk?
thanks in advance
NEW LED BULB OPTION
I just upgraded the LED bulbs to a much better type
LED PROJECTOR BULBS they can be found here
W5W T10 501
http://www.ebay.co.uk/itm/301445826489?_...EBIDX%3AIT
Here are the bulbs there are real good quality bulbs
and i would say there about 3 times as bright as the LED bulbs i had before
Here are the old LED bulbs and after a year they either flicker or half work
so yes they were cheap and were white but the new ones below are much better all round
And here are the new LED,s going in
You can see just how much brighter these LED,S are very happy with them
i will put a few pic,s up tonight in the dark for you all.
WELL HERE THEY ARE
REAR LIGHTS
SINGLE FRONT WELCOME LIGHT
AND ALL THREE COURTESY LIGHTS
very bright and A much better set of LED,S i am very happy.
Cool mate look forward to seeing them in the dark.
new LED,S updated.
They are much better mate.
They look really good! Good comparison, thanks
I'm about to order the projector LED bulbs for the interior but it says they aren't canbus ones. Will this cause an issue for the interior lights?
Not at all the interior lights are not on the canbus
and they really are the best they are pure white and the light out put is excellent.
i have had them in for a year now and still no problems what so ever.
Cheers.... 3 packs ordered. Lets hope that China mail is on fine form.
Just need to get number plate bulbs now
we can help you there also they are on the canbus and load resisters must be added
i have the ones in the thread below plug and play and they are error free and super bright.
http://www.vxoc.org.uk/forum/Thread-How-...late-Lamps
lol, you guys are the pinnacle of knowledge. I have so much to learn!!
your welcome
tucpal Wrote:NEW LED BULB OPTION
W5W T10 501
WELL HERE THEY ARE
REAR LIGHTS
Hey mate! want to upgrade to these myself and only need some for the front roof lights and the rear roof lights, would i just need to order 6 of the bulbs which you linked too? As in are they all the same shape and size or are there different sized/shape ones for the front and back?
I ordered three packs to do all the interior.
All the same size mate
awesome! will pick some up now
bhalay207 Wrote:I ordered three packs to do all the interior.
Cheers! Just done the same, how long did they take to come?
No more than a week I think. Either way I was impressed as they were coming from China.
Result then! can't wait to get mine swapped out as the stock ones suck! Ha
Let me know what they're like. Chances are you'll have yours fitted before I even collect my car lol.
Haha I will do mate! will fit them as soon as they arrive! Didn't realise you didn't have an Astra yet?! What's the hold up with it?
Well i technically do have an Astra. Its all paid for and what not but it had a cherished trransfer done by the previous owner,. The DVLA have sent out 2 log books which have got lost in the post meaning the dealer cant tax it which means i cant collect it! Just waiting on a V62 form now... Its been a nightmare to be honest. Clearly i'm committed to my J otherwise id have sought another one by now
Awwww damn dude! Not having a lot of luck are you! :( which model did you go for then and have you owned an Astra before?
No i'm not. I ordered it on the 10th of February so its dragged on like a dog with no back legs.
I went for a SRI with a 2.0CDTI engine. Its had a few tweaks by the previous owner which make it more appealing. I used to have a coupe which i loved but i had to get rid of it when we were having my eldest.
Oooo good choice! Kinda wish I'd have gotten a second hand higher model rather than a 1.7 brand new energy but oh well..more mods and retro fits for me to do hehe
What's been done to your SRI then?
Nice to have a brand new car though, plus you get to put your mark on it.
It's got tints, 19" anthracite wheels, powerfold mirrors, alloy pedals and door pins. Not sure if it's got anything else as I've not been able to have a good rummage around.
Got a few nice mods there then! You got a photo of your new car then? Be good to see it
Also did you think the door pins looked good? I'm in two minds as to whether or not I want to get some...bet you've already got a list of things you want to do to it hehe
Just a quick one from the dealer when i went to view it.
[ATTACH=CONFIG]358[/ATTACH]
[ATTACH=CONFIG]359[/ATTACH]
The pins look alright to be fair break up the black on black look
Those alloys look great!!! Really like that mate . Looks like it has tinted repeaters too but I could be wrong.
May have to invest in some metal door pins then, they're on my list anyaay ha
Ahhh yes, forgot those. It has lol. Sounds like a plan!
the alloy door pins do look really good much better than the black plastic ones
http://www.vxoc.org.uk/forum/Thread-Upgr...-door-pins
  How to ambient door lights tucpal 214 214,639 28:th-Mar-2021, 00:48:32
Last Post: Benk91
  how to install FOOT WELL LIGHTS tucpal 136 128,932 22:nd-Feb-2021, 08:00:17
  Super Bright Boot Lights sheppy1 26 29,086 12:th-Nov-2020, 17:54:59
Last Post: Arkanggel10
  How to fit courtesy lights in mirrors kyle-astra-j 21 26,503 18:th-Feb-2018, 06:15:13
Last Post: Leigh0274
  Upgrading Fog lights on J 5 door GarethMyers14 4 11,973 17:th-Nov-2017, 02:25:38
Last Post: sanj424
  How to Puddle Lights Rusty2009 22 34,688 6:th-Nov-2017, 20:16:44
Last Post: zzattack
  HOW TO LED TAIL LIGHTS tucpal 31 35,879 24:th-Oct-2017, 12:29:02
Last Post: Grimo72
  remove and upgrade SIDE REPEATERS tucpal 10 23,706 3:rd-Apr-2016, 21:02:38
