diesel then mode tank low erratic guage half fuel and threaded
Threaded Mode Diesel Fuel guage erratic low fuel and then half tank
Hi Guys
My Vauxhall Astra J 1.7cdti, Hatchback, 5 Door, 2011 61Reg.
My Diesel Fuel Gauge is was showing few days a Low in fuel and then after a bit showing half tank and then again low fuel.
However on the same day in the evening i just filled in £20 worth of fuel just to be on the safe side, but since then i have driven 1.5 miles, but not noticed the error of the low fuel.
What could it be is it the Pump, Float Valve or the Sender Unit ?
Do you have to take the seat out to access the pump or sender unit or the fuel tank underneath the car.
Thanks.
I had posted this on the wrong section , so i posting it again here.
I would say more the float but could be wrong.
  VAUXHALL ASTRA 1.7 CDTI FUEL SENDER UNIT 13272601- FUEL ERRATIC GUAGE BELWO HALF TAN caretaker 3 4,731 21:st-Oct-2024, 18:22:15
  Diesel door wont opel Arkanggel10 2 4,232 13:th-May-2021, 15:31:33
Last Post: Arkanggel10
  New Battery for Astra J 2013 reg 1.7 diesel Galway11 6 9,020 13:th-May-2021, 11:38:55
  Fuel pump needs priming? Amazingusername 3 4,416 21:st-Mar-2021, 20:34:09
Sad Astra 1.7 CDTI fuel quality problem klajdi 0 4,279 10:th-Sep-2020, 12:10:05
Last Post: klajdi
  ESP service message, erratic fuel range figures on trip computer mpotsb 2 6,449 7:th-Sep-2020, 12:04:29
Last Post: mpotsb
  Fuel Shutoff Valve NuttySqurill 1 3,751 12:th-Aug-2020, 07:58:08
  diesel question niteram 13 11,841 29:th-Mar-2020, 09:48:59
  astra j limp mode mark7 0 4,408 10:th-Feb-2020, 19:52:30
Last Post: mark7
  1.7cdti drinking fuel Hazard10 2 5,202 9:th-Jan-2020, 22:13:15
Last Post: Peckalz
