mpotsb - Replies:
ESP service message, erratic fuel range figures on trip computer
Dear All,
I have a couple of very recent issues with my 63 plate GTC 1.4 t and wonder if anyone can give me some advice.
One relates to the ABS warning light and traction control light illuminating on the dashboard together with an ESP service warning message on the trip computer. I think this might be a sensor issue somewhere.
The vehicle is running ok (ie no misfires, slightly slow pulling away like in a very slight limp mode when it gets to 2000 revs).
Is this an easy fix or somet
Threaded Mode Diesel Fuel guage erratic low fuel and then half tank
Hi Guys
My Vauxhall Astra J 1.7cdti, Hatchback, 5 Door, 2011 61Reg.
My Diesel Fuel Gauge is was showing few days a Low in fuel and then after a bit showing half tank and then again low fuel.
However on the same day in the evening i just filled in £20 worth of fuel just to be on the safe side, but since then i have driven 1.5 miles, but not noticed the error of the low fuel.
What could it be is it the Pump, Float Valve or the Sender Unit ?
Do you have to take the seat out to access t
VAUXHALL ASTRA 1.7 CDTI FUEL SENDER UNIT 13272601- FUEL ERRATIC GUAGE BELWO HALF TAN
Hi Guys,
I have fuel gauge which is fluctuating and some time it tells you the tank is low in fuel and sometime it is showing fuel gauge it is on ¼ tank, so I get warning sign low in fuel sometimes.
Sometimes if the tank is less than half full or even ¼ full and if you have parked half on the footpath and half on the road, after a bit it may show the tank looks empty, as soon as you drive it might go back to ¼ tanks display.
If I have my half tank and over the gauge there is no issue, as soon
