dump valve and boost guage
Any one fitted a boost guage and dump valve to there diesels yet if so how did you fit them
Threaded Mode Diesel Fuel guage erratic low fuel and then half tank
Hi Guys
My Vauxhall Astra J 1.7cdti, Hatchback, 5 Door, 2011 61Reg.
My Diesel Fuel Gauge is was showing few days a Low in fuel and then after a bit showing half tank and then again low fuel.
However on the same day in the evening i just filled in £20 worth of fuel just to be on the safe side, but since then i have driven 1.5 miles, but not noticed the error of the low fuel.
What could it be is it the Pump, Float Valve or the Sender Unit ?
Do you have to take the seat out to access t
VAUXHALL ASTRA 1.7 CDTI FUEL SENDER UNIT 13272601- FUEL ERRATIC GUAGE BELWO HALF TAN
Hi Guys,
I have fuel gauge which is fluctuating and some time it tells you the tank is low in fuel and sometime it is showing fuel gauge it is on ¼ tank, so I get warning sign low in fuel sometimes.
Sometimes if the tank is less than half full or even ¼ full and if you have parked half on the footpath and half on the road, after a bit it may show the tank looks empty, as soon as you drive it might go back to ¼ tanks display.
If I have my half tank and over the gauge there is no issue, as soon
