BMW 320 Day, night & race mode
ASTRA J OPC/VXR MODE
Hi guys, i was wondering if you could enable red dashboard lights on normal astra j ?
6ch tri-mode AMP
Does anyone know if there are any 6 channel tri-mode amps?
Been looking all over and can't find any any where.
VXR mode SMD conversion
Guys,
Ive changed the SMDs on the instrument cluster to have a blue under vxr mode and it wont change over to blue. All the connections are fine and when connected a multi meter to the LED's they all light up?
Has anyone else achieved this or is it something that i should have done...
Oli
engineering menu returns to default mode
I modify "sharx" and "high cut"in the hidden engeneering menu, is two functions in" tuner test", but when the car go off, the menu returns to before state.
Do Someone know how to resolve the problem?
Is there any solution for this?
Sorry for my bad english. Thanks.
The sharx funtion in 0 adjust resolve the bad reception an lost signal un fm...
navi 600 stuck in bootloader mode
Can anyone help me please.
I'm stuck in bootloader mode in my Insignia.
I was trying to upgrade from my navi 600 to navi 900.
If i cant get the upgrade ill have to replace the unit - can this be done and do i need to replace it all or just the cd or ?
Please help asap.
Matt
H5754 Recovery mode
Hello,
maybe someone knows how to get into this unit recovery mode?
Android version: 6.0.1
Kernel:
3.10.0
rocky@hctr930 #1074
Sat Jul 29 12:05:16 CST 2017
Build number: px5-userdebug 6.0.1 MXC89L user.hct.20170731.181825 test-keys
MCU version: MTCD_MX_V2.44d_1
2.0 CDTi SVS/Limp mode :(
Hello all
I recently bought a 2013 2.0 CDTi Elite. 35k on the clock.
On Saturday (hot day) it went into limp mode with the Service Vehicle Soon message. Engine was running at normal temp.
Took it to my local garage yesterday afternoon and they got back to me this afternoon.
They cleared the message and took it for a road test.
- Car temp went into the red and triggered limp mode again.
- One cooling hoses was red hot, the other stone cold.
They are going to continue looking into it
astra j limp mode
hi, got an astra j 2010 1.6 petrol.
keeps going into limp mode and traction control light is on and radiator fan kicks in instantly,
done a diagnostics at home and with vauxhall get loads of random codes but the 1 that is always there is p0366 ( camshaft sensors) had them changed and still no better,
a few people have said its the ecu so just had that sent for testing but they are saying they are unable to test it and wont say why.
any help would be really appreciated thanks
Threaded Mode Diesel Fuel guage erratic low fuel and then half tank
Hi Guys
My Vauxhall Astra J 1.7cdti, Hatchback, 5 Door, 2011 61Reg.
My Diesel Fuel Gauge is was showing few days a Low in fuel and then after a bit showing half tank and then again low fuel.
However on the same day in the evening i just filled in £20 worth of fuel just to be on the safe side, but since then i have driven 1.5 miles, but not noticed the error of the low fuel.
What could it be is it the Pump, Float Valve or the Sender Unit ?
Do you have to take the seat out to access t
