Coolant Tank
Fuel tank
So after vauxhall having my car for a number of days.
My fuel tank is a baffle less tank.
Anyone know why? As i can hear the fuel and is f*****g annoying.
sam2020 - Replies:
refuel sign comes up while the tank still more than halfway
hi all
i bought a vauxhall Astra 2013 its cat D recorded (just one door was damaged and has been replaced ) but now i have problem with the fuel warning it comes up and when i go the the patrol station to fill it up i find the tank still halfway full
does anyone have this problem before or any idea how to sort it out?
also i would like to know if the car still under warranty or the damage has a voided it? because im thinking to take it back to vauxhall ( i have proof of the previous door dama
gunx01 - Replies:
Coolant/ Expansion Tank Removal
Hi guys.
I had a quick look around but can't seem to find anything about removing the tank (has a crack and is leaking).
Anybody that could help? Does the battery have to come off?
Thanks in advance
Mile on a full tank,
Hi friends
i have had my car for almost 2 months now but i think it seems to be drinking to much fuel,
my car is a 2014 design estate model 6sp auto gear box 1.6... to fill my car is around the £60 mark but only seem to be getting around 320 miles, 1 fill up in auto mode and 2nd fill up in manual mode and 3rd fill a mix of both, but getting around the same miles, do you friends think my car has a drinking issue or is it about right? i think it works out around 28.9MPG (that is whats on the
coolant tank hose ref needed
hello guys,
im looking for this hose.. but i don't find the reference.
my tank is leaking, is wet on the sides, I think it is porous
i will change it but in same time i would like to change the bottom hose too. if anyone could help me with the part ref.
[Image: https://nsa40.casimages.com/img/2019/03/...437707.jpg ]
thanks to you !
tank replacement and still refill tank error
hey guys,
i changed coolant tank because mine leaked. everything was fine i replaced it and refill.
the level is to max. but i still have an error message on dashboard "level low please refill" i don't understand what is the problem..
Threaded Mode Diesel Fuel guage erratic low fuel and then half tank
Hi Guys
My Vauxhall Astra J 1.7cdti, Hatchback, 5 Door, 2011 61Reg.
My Diesel Fuel Gauge is was showing few days a Low in fuel and then after a bit showing half tank and then again low fuel.
However on the same day in the evening i just filled in £20 worth of fuel just to be on the safe side, but since then i have driven 1.5 miles, but not noticed the error of the low fuel.
What could it be is it the Pump, Float Valve or the Sender Unit ?
Do you have to take the seat out to access t
