battery agm regular or replacement
Battery replacement - AGM or regular
My battery is showing signs of needing a change as it is original Vauxhall AGM on my 62plate 1.7 Astra J GTC
My question is the replacement AGM batteries are quite expensive , can I go to regular flooded or will that cause me issues?
Thanks.
Sent from my moto g(8) plus using Tapatalk
[Image: 1ce359ab7d34d7967abbc95192b63305.jpg]
I got a replacement stop/start battery fitted from halfords for £152 recently with a 5 year warrantee (over £400 from eurocar parts!!) for my Cascada 2.0 CDTI. I'm glad they fitted it as ECU's and brackets had to be moved to get to the battery holding clamp!
  GTC Horn Replacement ed-b 1 3,366 12:th-Jul-2021, 08:53:37
  Glow plug replacement - Things to consider everson38 13 14,216 20:th-Jun-2021, 17:44:37
Last Post: everson38
  Disconnect battery Kiel0777 4 5,761 18:th-May-2020, 16:53:03
Last Post: Kiel0777
Thumbs Up Replacement discs and pads Iamthestig 3 6,854 23:rd-May-2018, 18:31:42
  Flexride shock absorber replacement rlievens 3 7,175 28:th-Feb-2018, 08:25:21
Last Post: rlievens
  Break Replacement sheppy1 15 19,538 17:th-May-2015, 21:40:02
