issue aftermarket android h5754 headunit
Aftermarket android H5754 headunit issue
Hi hope someone can help me ?
I purchased a h5754 head unit in 2018 and are still really pleased with my purchase ! , I have been playing with settings lately to try to get unit to stay on longer than 5 minutes when acc turned off which does not seem to be able to adjust !
Unfortunately during this process I have set default power setting to off - now I can not wake machine up at all , could anyone advise if there is any way to turn unit back on or resetting unit back to factory settings would solve my issue and if so how do I do this As looks like there is no reset button - just hole where memory card sits in screen module - thanks.
I would adviser talking to ROB at ICEBOX he may be able to tell you.
Other than that unplug the radio or pull the negative off the battery may work.
  DRL - sidelamp issue stajerad 1 4,305 12:th-Sep-2021, 15:37:54
  DRL/Sidelight Issue MassiveRoy 1 4,038 10:th-Feb-2021, 19:57:52
Last Post: Rhun91
  Tesla android over NAVI600 milozic 2 4,904 30:th-Jan-2021, 16:01:58
Last Post: dufferman87
  2 days and already an issue..... MrCrunchy 6 6,943 18:th-Sep-2020, 18:32:29
Last Post: MrCrunchy
  Aftermarket headunit malfunction prtklmb 2 4,519 28:th-Apr-2020, 09:08:35
Last Post: prtklmb
Thumbs Up Vibe microamp, will it fit behind headunit? s_p_a_r_k_e_s 3 5,788 8:th-Jan-2020, 08:13:56
  ASTRA J HEADUNIT ISSUE AstraJ_OwnerSK 1 4,576 10:th-Nov-2019, 08:31:13
  Sat Nav issue Slakky 3 6,181 2:nd-Sep-2019, 13:06:06
Last Post: vocky
  StabiliTrak/ABS Issue Desperado 1 5,860 17:th-Jun-2019, 09:31:05
  hatch issue Qaranc 4 9,186 2:nd-Jun-2019, 08:01:28
